LCD Problem
Results 1 to 16 of 16
Thread: LCD Problem
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Have you included a defines list like below?
    Note the lines define in the 10th line should be for 4 lines
    Define LCD_DREG PORTb ' Port for LCD Data
    Define LCD_DBIT 4 ' Use upper 4 bits of Port
    Define LCD_RSREG PORTb ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 0 ' Port Pin for RS bit
    Define LCD_EREG PORTb ' Port for Enable (E) bit
    Define LCD_EBIT 2 ' Port Pin for E bit
    DEFINE LCD_RWREG PORTb 'port for the R/W bit
    DEFINE LCD_RWBIT 1 'port pin for R/W bit
    Define LCD_BITS 2 ' Using 4-bit bus
    Define LCD_LINES 4 ' Using 4 line Display **************************
    Define LCD_COMMANDUS 2000 ' Command Delay (uS)
    Define LCD_DATAUS 50 ' Data Delay (uS)
    Peter Moritz.
    New South Wales,
    Australia.
    Aug 2005
    Tried adding the defines but no joy, still the same result. Ill just wire all the data pins up and see if that works. If no joy ill just resign it to the scrap bin of life.
    Thanks all Sphere.
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. LCD problem
    By Andre_Pretorius in forum General
    Last Post: - 27th January 2009, 16:47
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Need help with LCD number display.
