Help with pic16F877
Results 1 to 3 of 3
    fadibasic's Avatar
    fadibasic Guest
    Default Help with pic16F877
    Hi guys,
    I am not sure if it will be an issue or not, but I want to ask a question about portA.4
    I have read the spec sheet, and PortA.4 is an open drain, which means current will always flow to the microchip.
    what I am worry about is if the microchip is safe if I have a transistor (emitter side) connected to the pin, the Base (B) connected to the 5 Vdc and the collector (C) to 24Vdc.
    Can PortA.4 be configured so that it becomes an output. so that it behaves just like the other PortA pins.
    Jan 2006
    Istanbul
    Why don't you pull this pin to Vdd with a resistor, say 10K or 4K7 ?
    fadibasic's Avatar
    fadibasic Guest
    Please can you explain to me what happens if we do that?
    what do you mean by PULL? like I split the current going to PortA.4 with VDD.
  1. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  2. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 11:02
  3. Replies: 8
    Last Post: - 17th January 2007, 20:18
  4. Ericsson T10 interface with PIC16F877
    By jam547 in forum GSM
    Last Post: - 25th March 2006, 23:27
  5. USB interface from PIC16F877 to PC
    By headshouter in forum USB
    Last Post: - 26th February 2006, 05:58
