I'm trying to write code for some hardware I'm going to build. With two purposes:
1) I have a 4-bit hex rotary encoder that will be inputs to the lower 4 bits of portA. I want the LCD to display an ASCII of the HEX encoder value.
2) I also have 4 momentary switches. They will be the lower 4 bits of portB. I have 4 LEDs on portC. When I press a momentary switch on portB, I want the cooresponding LED on portC to light & latch. When any other button is pressed, I want the first LED to go low and the new LED to go high and latch. Basically, I want portC to output & latch any value of portB other than 0.
All MCU inputs are optically isolated from the hardware they are operating.
I'm really new at this & this is my first code other than simple LED out type programs. Here is what I have:
The whole thing compiles fine except for Error Line 44: Syntax Error. Is this line 44 of the PBP or the ASM code? Does that include blank lines and comments as a line? In other words: which is line 44?Code:'program for integrated firing panel 'portA = hexadecimal rotary encoder input (value to be displayed as an ASCII on LCD) 'portB = 4bit bank select momentary switches input 'portC = 4bit output to bank LEDs 'message = LCD display of portA (hex switch) value 'initialize device @ device pic16f737, INTRC_OSC_NOCLKOUT, MCLR_OFF OSCCON = $60 '4mhz internal oscillator 'initialize ports TRISB = $10 'make all portB pins outputs except B.4 TRISC = 0 'Make portC outputs PORTC = 0 'Make sure portC pins start low 'initialize variables TxPin var PORTB.4 'alias pin B.4 to "TxPin" rotary_in var word 'create variable "rotary_in" banks var word 'create variable "banks" rotary_in = PORTA & $0f 'isolate lower 4 bits of portA & write to "rotary_in" banks = PORTB & $0f 'isolate lower 4 bits of portB & write to "banks" LEDs var PORTC 'alias PORTC as "LEDs" 'Initialize Display Pause 1000 'pause 1 sec to let LCD initialize serout TxPin,4, [22] 'turn display on, no cursor serout TxPin,4, [17] 'turn backlight on serout TxPin,4, ["Firing Panel v1"] serout TxPin,4, [148] 'move to line 2 serout TxPin,4, [2] 'display custom character 3 pause 5000 serout TxPin,4, [22] 'clear the screen pause 2000 message: serout TxPin,4, [22] 'Clear LCD serout TxPin,4, [128] 'move cursor to beginning of first line serout TxPin,4, ["Panel Selected:"] serout TxPin,4, [199] 'cursor to middle of second line serout TxPin,4, [#rotary_in] 'display ASCII of portA lower 4 bits on LCD END leds: If banks > 0 Then 'for all port B.0 thru B.3 values, except 0, banks = PORTC 'write value of portB to portC Endif goto message 'loop LCD forever End
Any help would be appreciated. I know most of you could find much better ways of writing this, but I need to keep it simple, even if it isn't the most efficient way of doing this. That way I can continue to work with it and learn from it in the future. The inputs and outputs will be so slow that speed isn't an issue.
One thing I don't like is that in the "leds:" routine, I'm writing a binary value to the whole portC when portC.4 is TxPin. Not sure if this will create problems.
Attached is the assembly file created by PBP.
