PIC16F690 PBP boundary crossing warning message
Results 1 to 4 of 4
    xnihilo's Avatar
    xnihilo Guest
    Default PIC16F690 PBP boundary crossing warning message
    Hello,
    Does someone know what is the meaning of the error message:
    102: code crosses boundary @800h
    although the code compiles fine. I should have enough program memory so why this warning?
    One more thing, CMCON0 is not recognized with a PIC16F690 while is is fine with 16F684, why is that?
    Always worthwhile to do a search
    Warning (and other Compilation Error) Messages
    http://www.picbasic.co.uk/forum/showthread.php?t=555&
    and this
    http://www.picbasic.co.uk/forum/show...02&postcount=1
    and finally.... you may discover that you can disable it in MicroCode Studio
    And download/read the PIC datasheet to discover why CMCON0 is not recognized. Table 8-2 should give you some reasons
    Oct 2003
    holland
    just a warning it's ok. When you do a search on this statement here on this forum you will find this question with answers a few hunderd times.
    Wheb you read the datasheet of this component you see that there is no cmcon register.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    okay. no cmcon0 register but cm0con0 and cm1con0 register where i neeed to clear bit 7 for both.
    i should read the datadheet for the 16f690 and not assume it has t e same specs as 16f684.
    thanks.
  1. Crossing Page Boundary - Solution
    By Darrel Taylor in forum FAQ - Frequently Asked Questions
    Last Post: - 24th November 2007, 03:52
  2. Micro Code Studio - Warning message
    Last Post: - 17th November 2006, 22:17
  3. MicroCode Studio Boundary Warning Message
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 16th March 2006, 10:13
  4. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
