1-Wire
Results 1 to 10 of 10
Thread: 1-Wire
    Quote Originally Posted by WarPony View Post
    Think so
    How's this?
    Well, not so good.
    There is only 1 Alarm status bit, No SkipROM, and mode 4 (bit data) is used to retrieve it after the AlarmSearch command.
    Alarm   VAR BIT
    OWOUT   DQ, 1, [$EC]
    OWIN    DQ, 4, [Alarm]
    If there is an alarm, you have to read the temperature to figure out whether it's too high or too low.
    It will return a 0 if there is an alarm, 1 if not. But you can reverse that easily with...
    Alarm = Alarm ^ 1
    hth,
    May 2008
    Texas
    Smile
    Thanks Darrell
    I see. I forgot to change the mode bit. Still learning.
    I really need a setpoint temperature for the "smarter" HVAC thermistat I am working on. I think I will just use another 18B20 as my setpoint temp and not worry about the alarms.
    You lost me there.
    Using another 18B20 as a setpoint, would make it a "Variable point".
    If you want to make a thermostat, it's probably easiest to just read the temperature and compare it against the desired "setpoints" in your program.
    May 2008
    Texas
    Absolutely
    I am entering a setpoint in the software and also going to have another 18B20 outside to give me the "variable setpoint". This way the system knows if it really needs to turn on or to just pause until it warms up or cools down
    Thumbs up
    AH HA! I see now.
    Very good. Carry On.
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
