1-Wire
Results 1 to 10 of 10
Thread: 1-Wire
    May 2008
    Texas
    Question 1-Wire
    Can anyone help me with the syntax for writing to a one-wire devices scratch pad?
    I want to set the Th, Tl, and config bytes (byte 3,4,5).
    I was thinking
    Owout PortX.X, 1, [$CC, $4E] 'skip ROM search and write to scratch pad
    Owout PortX.X, 1, [$XX, $XX,$XX] bytes 3, 4, and 5
    Do I need place holders for the first to two bytes on the scratch pad? If so, what is that syntax?
    It looks like you are using a DS18B20.
    It's best to include that kind of information with the questions.
    If not then this won't apply.
    DS1820 resolution
    http://www.picbasic.co.uk/forum/showthread.php?p=47692
    May 2008
    Texas
    Default 1-wire
    Thanks old chap
    i have been beating my head into the wall
    I understand the alarm registers are 8 bit with the MSB being the sign bit. Is that a straight decimal conversion? i.e. 25 degrees Celsius would be %00011001
    Again
    Thanks a lot
    Sure, that'll work. Added: (not the beating your head part)
    Or you could just use 25.
    OWOUT DQ, 1, [$CC, $4E, 25, 0]
    High limit = 25°C
    Low limit = 0°C
    If you want to use negative alarms, it's easier to use a variable
    LowLimit   VAR BYTE
    HighLimit  VAR BYTE
    HighLimit = 20
    LowLimit = -10
    OWOUT DQ, 1, [$CC, $4E, HighLimit, LowLimit]
    Do you know how to read the alarm status yet?
    <br
    May 2008
    Texas
    Think so
    How's this?
    Alarm_H VAR Bit
    Alarm_L Var Bit
    Owout DQ, 1, [$CC, $EC]
    Owin DQ, 1, [Alarm_H, Alarm_L]
    Is it going to send back a 1 or 0 alarm bit?
    Quote Originally Posted by WarPony View Post
    Think so
    How's this?
    Well, not so good.
    There is only 1 Alarm status bit, No SkipROM, and mode 4 (bit data) is used to retrieve it after the AlarmSearch command.
    Alarm   VAR BIT
    OWOUT   DQ, 1, [$EC]
    OWIN    DQ, 4, [Alarm]
    If there is an alarm, you have to read the temperature to figure out whether it's too high or too low.
    It will return a 0 if there is an alarm, 1 if not. But you can reverse that easily with...
    Alarm = Alarm ^ 1
    hth,
    May 2008
    Texas
    Smile
    Thanks Darrell
    I see. I forgot to change the mode bit. Still learning.
    I really need a setpoint temperature for the "smarter" HVAC thermistat I am working on. I think I will just use another 18B20 as my setpoint temp and not worry about the alarms.
    You lost me there.
    Using another 18B20 as a setpoint, would make it a "Variable point".
    If you want to make a thermostat, it's probably easiest to just read the temperature and compare it against the desired "setpoints" in your program.
    <br>
    May 2008
    Texas
    Absolutely
    I am entering a setpoint in the software and also going to have another 18B20 outside to give me the "variable setpoint". This way the system knows if it really needs to turn on or to just pause until it warms up or cools down
    Thumbs up
    AH HA! I see now.
    Very good. Carry On.
    <br>
  1. Thermo 7 segments - little problem
    By fratello in forum mel PIC BASIC Pro
    Last Post: - 27th July 2013, 07:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 14:23
