error pbp and mplab id
Results 1 to 3 of 3
    Feb 2005
    Default error pbp and mplab id
    i install mplab ide ver 8 and pic basic pro 2,47.i am receiving and following error when i try to compile:"
    Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z -p16F876 "BLINK.BAS"
    PICBASIC PRO(TM) Compiler 2.47, (c) 1998, 2006 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to execute mpasmwin.Halting build on first failure as requested.
    BUILD FAILED: Thu May 08 13:44:59 2008
    This means that can't find the asm compiler of microchip but i can't find solution.everything is on default folders.what can i do?
    thanks
    Have you followed the instructions here?
    http://www.melabs.com/support/mplab.htm
    Feb 2005
    oups.i forgot to change the path variable.i did it and work ok now without errors.
    thanks mackrackit for your reply.
    regards
  1. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 01:15
  2. pbp --> mplab broken again
    By kenif in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 18:57
  3. Microcode Studio MPLAB support
    By jbpaul in forum General
    Last Post: - 27th November 2006, 06:55
  4. melabs USB programmer into MPLAB?
    By jocovo in forum General
    Last Post: - 10th November 2006, 16:58
  5. MPLAB ICD ver 1 & 16F628A
    Last Post: - 26th February 2005, 00:44
