Linux
Results 1 to 5 of 5
Thread: Linux
    Default Linux
    Has anybody had success running PBPro and MCS+ on a Linux machine?
    I am tempted to get an ASUS EEEPC as a PDA, ebook reader and hopefully a PIC Dev system in a tiny footprint but I know diddly squat about Linux.
    BrianT
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by BrianT View Post
    BrianT
    I haven't played with Linux much myself. I loaded up Ubuntu 8.04 on my desktop a couple of weeks ago, dual booting with WinXP.
    Piece of cake to load it, got it on a single partition on the slave hard drive. The installer handled everything.
    A bit of a pain to use it, until you get used to the 'new' way of doing things. Folders aren't laid out quite the same, devices are named a bit differently, drivers don't install/remove quite the same, and so on and so on...
    Everything seems to work fine on my Dell Inspiron 8200 (including the USB 802.11g adapter)...can't say for sure about the EEE, even if it says that the EEE 'comes with Linux'. I gotta wonder how complete it is?
    I asked the same question myself a couple of weeks ago. According to *insert name here*(I forget who it was), MCS and PBP run just fine under WINE (a Windows -recompiler/emulator- that runs in Linux), but couldn't get the PICKIT2 software to run in Linux.
    Sep 2005
    Campbell, CA
    PBP and MCS do run fine under Ubuntu 8.0.4 - and WINE
    MCLoader comes up, but so far I can't get it to recognize the serial port.
    Charles Linquist
    I use MPLAB and PBP with the PICSTART PLUS (serial port) under wine.
    Can not get the PICKITs 1 or 2 (usb) to work though.
    When you set MPLAB up to use PBP as a language suite you have to work in the virtual registry. Not like in XP where there is a dialog box to add the path. When/if you need help on this let me know.
    How could you
    skimask's Avatar
    skimask Guest
    How could you
    I could, I did, and now, I remember...
  1. Control a Linux PC?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 28th July 2009, 03:39
  2. Replies: 6
    Last Post: - 11th November 2007, 22:14
  3. Linux with PBP
    By sayzer in forum PBP Wish List
    Last Post: - 8th August 2006, 22:27
  4. LINUX IDE and PBP
    By mslaney in forum General
    Last Post: - 5th January 2005, 21:43
  5. Linux
    By mackrackit in forum mel PIC BASIC Pro
    Last Post: - 5th February 2004, 22:56
