dtmfout problem
Results 1 to 23 of 23
Thread: dtmfout problem
    I'm not sure what affect it will have on DTMFOUT, but you have ....
    ANSEL = 1
    Which puts PORTA.0 in Analog mode.
    And that's the DTMF pin.
    Might try ...
    ANSEL = 0
    Sep 2006
    that did not work,
    everytime a DTMF comes out, its like someone was blowing air at the same time.. from what I can hear from the speaker.
    if I choose to do a low pass filter, what would you suggest my cut off frequency be?
    Quote Originally Posted by lerameur View Post
    Well, since DTMF freq's run from 697Hz to 1633Hz (reference Wikipedia), shooting for 1634 would be a good bet, but probably not practical. I'd tend to think that a 'brick wall' above 2KHz would do it.
    And I'd also be willing to bet that the 'air' you are hearing is in fact aliasing of the fundamental tone due to the numerous harmonics caused by the square wave output of the PIC.
    Mar 2006
    China
    Default Low pass
    What do you plan to design the filter? RC? OP-amps? LC? go for a filter chip?
    Sep 2006
    I dont know yet, but I remember some chip requires +15 and 15- supply , I only have about 6 or 7v supply.
    I tried a single stage RC, with 0.2uF and 400ohms, that did not do anything..
    .2uF & 400 ohm gives you an RC time constant of 12.5Khz. (.2/1000000 * 400 = .00008, 1/.00008 = 12,500)
    It might work a bit better if you had a bit more cap's and a bit less resistor, say 40 ohms instead of 400, which would give you an RC time constant of 1.25Khz. And since you're trying a single stage RC filter, the roll-off would be fairly shallow, so 1.25Khz may work out fairly decent.
    My suggestion...get a copy of 'The Art of Electronics'. It's one of my 'Good Books', take it with me on every trip I take, page thru it all the time. A few good sections on filters, op-amps, etc.etc.etc.
    Sep 2006
    ok look at this pdf:
    AN6_DTMF_gen.pdf
    search for it on google, last page shows the calculation i did.
    aslo, when I used my 0.2uF cap. I decided to switch to a variable 2k pot, went through all the resistance values pretty quicky. The only thing this did is to increase or decrease the overall sound level, kind of a volume control.
  1. Button problem driving me crazy!! Please help!
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 20th November 2007, 15:46
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 15:30
