Any real circuit and code of that? Are you using 20MHz crystal?
The noise is always there?
From the data I have here,...
I see a damping 680 Ohm res. on the Pic side of the line trafo. ( // with the winding !!! )
On the line side :
in series with the primary :
750 Ohms 2W // 1µF // TPJ ( to limit current to ~ 35 mA )
I am using 20Mz
I think the problem is more hardware than software..
code:/
'* Alarm system dialer *
'// Pic chip configuration //
INCLUDE "modedefs.bas" 'Includes supoprt for PicBasic language
@ DEVICE pic16F88,CCPMX_ON
' Setup Crystal oscillator Frequency to be used by PIC chip in MHz
DEFINE OSC 20 'use external 20mhz crystal
ANSEL = 1
CMCON = 7 ' Turn OFF the comparators so pins can be used as digital I/O-pins
'// Screen initialization //
DEFINE LCD_DREG PORTB ' Set LCD Data port
DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTA ' Set LCD Register Select port
DEFINE LCD_RSBIT 2 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTA ' Set LCD Enable port
DEFINE LCD_EBIT 3 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
pause 2000
'// PIN configuration //
TRISA = %00011000 ' Set PORTA to all input
TRISB = %11111111 ' Set PORTB to all output
PortA = 0
'// Variable Declaration and initialization //
counter var byte
i var byte
counter=0
'// Program starts here //
lcdout $FE,1, "Counter:",dec counter
Pause 500
if PortA.4=1 then
counter=counter +1 'Counter at 1 dials phone number
goto Dial
if PortA.4=0 then
counter=0
goto Main
'// End of program here //
Dial:
'Determine which number to dial and dials it
lcdout $FE,1, "Dial:",dec counter
Pause 500
if counter =1 then 'begin counter loop
if PortB.0 = 1 then GOSUB Dial1760 'cel
if PortB.1 = 1 then GOSUB Dial4392 'Ken
if PortB.2 = 1 then GOSUB Dial9130 'Donald
if PortB.3 = 1 then GOSUB Dial758 'Lyne
Else
counter =1
goto Main
endif 'end counter loop
Pause 1000 'pause for 1 seconds
if (counter > 1) or (counter =0) then counter =1
'Keep counter to 1 after dialing, otherwise the program will keep dialing the number
' Will only redial if counter goes back to 0, that is alarm siren off
goto Main
'*************** subroutine here ********************
Dial1760: 'cel
lcdout $FE,1, "dialing1760 ",dec counter
Pause 500
PortA.1 = 1
pause 3000
DTMFOUT PortA.0, [5,1,4,4,4,4,4,4,4,2]
pause 4000 'Pause 4 seconds
DTMFOUT PortA.0, 20000,0, [5]
pause 2000 'Pause 2 seconds
PortA.1 = 0
/end code
I think I might got the probe switch to 10x instead of 1x.. that would explain the 40v. I will check it once I get home...
if so I guess I would have would have something like 3.7v output peaks on the pin.
Ok , the scoipe was set at 100x. now I read 4v at the output, but still a lot of noise after the filter, and only dials 50% of the times
k
Well, the PBP manual does say that any 'sound' output from the PIC, being 1-bit analog, is going to be 'noisy', a lot of harmonic content. And I would think that even if it's filtered well, it would still have a load of 'noise' in it. A low-pass 'brick wall' filter, with a steep 'slope/cutoff', with the -3db point set just above your highest frequency might handle that.
I guess I'm not really sure. I haven't relied on the PIC to do much sound (other than moving MP3 data back and forth for a player).
I was initially thinking of going with a specialized DTMF chip. They are hard to get around here
