Instability with the 12F629
Results 1 to 10 of 10
    Fayetteville Arkansas
    Default Instability with the 12F629
    I am very much a newby to these.
    Below is the code that I write originally my input was pin 7, but for some reason I could not get it to triger with a switch. The intent is to give the input pin a high by using a momentary switch, which will cause pin 6 to go hi for 2 seconds, then pin 5 for 2 seconds, the timeout for 3 seconds and then wait for another trigger event. When my hand gets near the switch which triggers pin 3, it triggers. If I get near it it tends to do the same. Any quips of wisdom would be appriciated.
    Butch
    SEN VAR GPIO.4
    POW VAR GPIO.1
    SHT VAR GPIO.2
    LOW SEN
    LOW POW
    LOW SHT
    INPUT SEN
    OUTPUT POW
    OUTPUT SHT
    LOOP:
    IF SEN=1 THEN
    HIGH POW
    PAUSE 2000
    LOW POW
    HIGH SHT
    PAUSE 2000
    LOW SHT
    PAUSE 3000
    GOTO LOOP
    New England
    Default Re: Instability with the 12F629
    That you HH?
    Have not used used any of the 12 series yet - but you might want to post some of your code that shows your 'configuration' settings.
    Yep Arch, its me. Hey, I said I'm a newby, that IS all my code.
    Good to see ya
    thelightbrain's Avatar
    thelightbrain Guest
    The input pin that you are connecting the switch to should also be connected to ground via a 5K or 10K resistor. This will keep it from "floating".
    Or, to avoid adding another component, you can enable the internal "weak pullups" and connect the switch to ground. And change the input polling code to:
    IF SEN=0 THEN
    Also vave to make sure the input your using has the weak pullup.
    --Jim
    Thanks Jim, I'll give that a try.
    New England
    Hey Butch - good to see ya starting on the programming - stuffs almost as addictive as the cams !!
    Was just looking over the 12F629 data sheet and it looks like it has lots of functions like comparators, A/D inputs, and such.
    There will be a bunch of registers like INTCON and OPTION_REG that are pre-set by PBP - you'll sometimes need to set them up manually in order to make sure all your pins are functioning as digital In/Outs, etc (unless you want the analog stuff).
    Caused some headaches for me on the 16F628's until I figgured it out (Brian helped out a lot!).
    Don't know what the PBP presets are for the 12F629.
    You might want to use the GPIO.2 'external interrupt' pin as your sensor input and assign weak pullups and trigger on falling edge (see INTCON and OPTION registers in data sheet).
    I think the "ON INTERRUPT" command could then be used while you put the chip to sleep (not sure on the '629).
    Arch
    It can Arch. Was on Yahoo with Stevo and figured out there is even more I need to learn. Thanks for the input
    PIC12F629 have internal comparator
    to turn them of
    CMCON=7
    here a link for some specific setting on some PIC
    http://www.melabs.com/support/mcu_hints.htm
    regards
    Dec 2003
    Wichita KS
    Hello BGreen,
    BG>>When my hand gets near the switch which triggers pin 3, it triggers. If I get near it it tends to do the same. Any quips of wisdom would be appriciated.<<
    When you program the chip, Make sure your MCLR is set to input pin. If not, your body can difinitely turn this chip on and off. I ran into this just by touching things, and finally realized the Mclr was set to reset. You can pull it high if you don't want to set it as a input, and accomplish the same thing.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Folks, thanks for the help. I used a 4.7k resister from the switch to ground and its solid as a rock. I had already put a pullup on pin 4. Jig I built is working fine. Now I need to learn the right way to do stuff, and how to use the sleep and interupts.
  1. Input problems with 12F629?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th April 2018, 07:25
  2. Basic help for 12F629
    By Gene Choin in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 05:06
  3. sleep on 12f629
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 15:08
  4. Servo control with 12F629
    Last Post: - 24th June 2005, 00:34
  5. 12F629 I2C problems
    By AIW128ProGuy in forum mel PIC BASIC Pro
    Last Post: - 12th November 2004, 00:41
