TTL or ST? What is it?
Results 1 to 4 of 4
    xnihilo's Avatar
    xnihilo Guest
    Smile TTL or ST? What is it?
    I am a bit lost.
    Reading the datasheets of 16f684 and 16f685 I see that the pins are not using the same input types.
    Some are using TTL and some are using ST.
    What is the difference?
    Dec 2005
    Quote Originally Posted by xnihilo View Post
    See the DC Characteristics section of the datasheet. TTL is Transistor-Transistor Logic. It takes lower voltage to trigger the input. ST is Schmitt Trigger which requires higher voltage to trigger the input.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    I read some stoff on wikipedia.
    I'm wondering why they didn't use either TTL or ST for all pins...
    Moreover, do I need something special if it is TTL? Just a voltage of 5V, right?
    Read some more stuff on wikipedia on "hysteresis".
    Then some of the benefits and/or drawbacks of an ST input will become more clear...
  1. TTL magnetic card reader interface ith PC
    By attabros in forum Schematics
    Last Post: - 24th February 2016, 08:04
  2. ST micro LIS3LV02DL accelerometer interfacing
    By devil6600 in forum Serial
    Last Post: - 17th May 2008, 16:29
  3. Lowest readable input voltage?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 7th January 2008, 11:12
  4. Ttl - Rs232
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 13:11
  5. TTL input - 3rd states possible?
    Last Post: - 31st March 2007, 17:04
