Serial VB 2005 pic 16f877a problems
Results 1 to 29 of 29
    Valid for Timeout use...
    Ayy......good point...
    But what if the serial cable is 'amplifying' the unloaded pin, as in a floating input, and it ends up causing garbage to try to get into the SERIN statement.
    How about adding a pullup or pulldown as appropriate?
    He said he use MAX232
    But yes i see what you mean.
    Apr 2007
    Southern Ontario
    ok, I took out the pause, added the #, so the serin now looks like this...
    serin portc.3,t2400,10,mainloop,[#pcsig]
    it still locks up,
    i added a 4.7 pull down to rx, no luck
    pull up no luck
    serial cable still not even connected (just trying to get it to run first with serin command intact)
    will keep trying
    thanks
    Beer is proof that God loves us and wants us to be happy.
    nope... no square brackets in that.
    Apr 2007
    Southern Ontario
    how is this.........still does not work.
    serin portc.3,t2400, 10,mainloop,#pcsig
    seems i'll need to try it here
    can you post your missing class or your whole VB code please?
  1. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 00:26
  2. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  3. PIC serial going to sleep!
    By stma in forum Off Topic
    Last Post: - 31st October 2007, 08:17
  4. PIC to serial with visual basic
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 31st March 2007, 16:06
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 4th April 2004, 23:58
