Serial VB 2005 pic 16f877a problems
Results 1 to 29 of 29
    Apr 2007
    Southern Ontario
    Default Serial VB 2005 pic 16f877a problems
    Hi I m back with a new project. Thank you for all you help and support on the slot car timmer. I am working on a simple thermostat withthe 1620 chip and it works great with the lcd out. I wanted to get it to the pc so I wrote a small program in VB2005 and it took hours just to get them talking but I did it... except the pic is not listening. I can send to vb fine and read it but when I try and send back to the pic it does not get it. I can see the PC trying to send out on the scope but it does not get stored in my pic variable. I even ran a wire from the tx side of the pic to the rx and still nothing. The pic is sending but not recieving.
    here is some of my code
    I decalred the variable as a word and later as byte
    I am using a max 232 converted and like I said I can see both signals on the scope
    I am sure the pc it sending the code i think
    I am just trying to get the pc to tell the pic to turn on a fan when it gets too hot.
    YES I know there are many simpler ways to do this directly threw the pic but I want to use the PC.
    serout portd.3,t2400,[#temp]
    serin porta.0, t2400,pcsig ' my data in variable
    if pcsig > 1 then high porta.1 ' pc writes 100 so even if the pic gets anything it should fire
    thanks again
    Snap
    Beer is proof that God loves us and wants us to be happy.
    There's quite a few culprit in VBExpress, that would be really nice if you could post your VB and the whole PIC code here.
    As you're using PORTA... make sure you have disabled the ADCs
    PortA Doesn't Work & Common 8-Bit PIC® Microcontroller I/O Pin Issues (TB3009)
    Any specific reason why you don't use the built-in PIC USART?
    Quote Originally Posted by Snap View Post
    Snap
    I have found this http://www.serial-port-monitor.com/index.html utility extremely useful while doing anything with VB and the serial port.
    Also, if you have another serial port, try and read what your VB code is in fact sending although serial port monitor would do the same anyway.
    Anand
    T.Jackson's Avatar
    T.Jackson Guest
    Don't ever leave this forum mister_e, my life depends on you being here sharing your knowledge. I think I speak for everyone.
    Apr 2007
    Southern Ontario
    Smile
    Hello again, Ok I switched off the adc'd with adcon1 statement.
    And that must have done something because now everytime I start the program it locks up at the display temp part.
    If I remove the serin code it works (just the program not the recieve signal from the PC)
    If I remove the wire from the serin port to the rx on the max 232 adapter it works
    This is all when the PC is not even plugged in the the max 232
    the wire seems to be shorting out the program or the signal is screwing it up
    To me the USART seems to be more work then a simple serin command why would I use it?
    here is the pic code
    Include "MODEDEFS.BAS"
    DEFINE LCD_DREG  PORTB
    DEFINE LCD_DBIT   0
    DEFINE LCD_RSREG  PORTB
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG  PORTD
    DEFINE LCD_EBIT 7
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATUS 50
    ADCON1=%00000111
    RST var portd.2
    DQ var portd.0
    CLK var portd.1
    temp var word 'storage for temperature
    pcsig var word
    low rst 'reset 1620
    lcdout $fe,1,"Temp in Degrees C"
    ' Main loop
    mainloop:
    RST = 1'enable device might be high
    Shiftout DQ,CLK,LSBFIRST,[$ee] 'send read command
    RST = 0 ' reset device
    Pause 1000 ' wait for conversion to compleate
    RST = 1 ' SAA
    Shiftout DQ,CLK,LSBFIRST, [$aa] ' send read command
    Shiftin DQ,CLK,LSBPRE, [temp\9]'read 9 bits temp
    RST = 0
    lcdout $fe,1,dec(temp>>1), ".", dec(temp.0*5), " Degrees C"
    serin porta.1,t2400,pcsig
    lcdout $fe,1,pcsig,"pcsig"
    goto mainloop
    Here is the VB code
    I ommitted a class
      Public Class Form1
        Dim WithEvents serialport As New IO.Ports.SerialPort
        Dim temperature As Integer
        Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
            If serialport.IsOpen Then
                serialport.Close()
            End If
            With serialport
                .PortName = "com1"
                .BaudRate = 2400
                .Parity = IO.Ports.Parity.None
                .DataBits = 8
                .StopBits = IO.Ports.StopBits.One
                '.DtrEnable = True
                '.ReadBufferSize = 40
                .ReceivedBytesThreshold = 2
            End With
            serialport.Open()
        End Sub
        Private Sub Datarecieved(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles serialport.DataReceived
            TextBox1.Invoke(New mydelegate(AddressOf updatetextbox), New Object() {})
        End Sub
        Public Delegate Sub mydelegate()
        Public Sub updatetextbox()
            Dim mytemp As New temp
            mytemp.binary = serialport.ReadExisting
            Dim resultc As Decimal = celciusconversion(mytemp.binary)
            Dim resultf As Decimal = farconversion(resultc)
            TextBox1.Text = resultc
            TextBox2.Text = resultf
            If resultc >= 24 Then
                'serialport.Write("a")
                serialport.Write(100)
                TextBox3.BackColor = Color.Green
                TextBox3.Text = "fan on"
            Else
                TextBox3.BackColor = Color.Red
                TextBox3.Text = "fan off"
            End If
        End Sub
        Public Function celciusconversion(ByVal datarecieved As String) As Decimal
            Return datarecieved * 0.5
        End Function
        Public Function farconversion(ByVal datarecieved As String) As Decimal
            Return (datarecieved * 1.8) + 32
        End Function
    Thank you for your time.
    I am trying to help out on this forum as much as I can, I have been sending copies of my slot car timer to users who ask for it.
    this should send string, so i guess you'll need to change the SERIN to
    serin porta.1,t2400,#pcsig
    I'll second Ardhuru's advice. A serial COMport sniffer is always handy to have on hand. I use HHDSoft's one
    http://www.hhdsoftware.com
    There's a load of those here and there, some are 100% free.
    Having one on hand... priceless!
    Apr 2007
    Southern Ontario
    Thanks for the reply but the problem is that the program is now (after fixing port a) locking up as soon as I connect the rx pin on the 232 adapter, the serial cable is not even connected and it locks up.
    if i comment out the serin code with the 232 connected it works (without serin)
    I think the serin command is locking up the program but I don't know why.
    The voltage is always 5 volts untill a code comes threw would a constant 5 volts mess up the serin pin? this is a falling trigger do i need to tell the pic what type to look for?
    t2400 ? n2400?
    I hope I have given enough information, I have been.
    what would cause the program to lock up as soon as i connect the serin pin?
    thanks again
    Apr 2007
    Southern Ontario
    Smile Sweet Sweet Successsss
    I finaly did it (or should I say We....Mr e).The program works fine.
    The key hang ups were add in a "z" in the VB write code and sending code all the time to the pic. Im sure there are way better ways of doing this but this works.
    You need a pic and a 1620 temp ic and a serial converter and a pc.
    here is the code and thank you everyone who helped especially the big E.
    Snap
    VB2005 code
     Public Class Form1
        Dim setting As Decimal
                serialport.Close()
            End If
            With serialport
                .PortName = "com1"
                .BaudRate = 9600
                .DataBits = 8
                '.DtrEnable = True
            End With
            TextBox4.Text = 23
            serialport.Open()
            serialport.Write(200 & "z")
        End Sub
        End Sub
            If TextBox1.Text >= setting Then
                serialport.Write(100 & "z")
            ElseIf TextBox1.Text < setting Then
            End If
        End Sub
        End Function
        End Function
        Private Sub Label1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label1.Click
        End Sub
        Private Sub Label4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label4.Click
        End Sub
        Private Sub Label2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label2.Click
        End Sub
        Private Sub TextBox4_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TextBox4.TextChanged
            setting = TextBox4.Text
        End Sub
        Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        End Sub
    End Class
    Temp Class
    Public Class temp
        Private m_binary As String
        Private m_celsius As String
        Private m_farenheight As String
        Public Property binary()
            Get
                Return m_binary
            End Get
            Set(ByVal value)
                m_binary = value
            End Set
        End Property
        Public Property celsius()
            Get
                Return m_celsius
            End Get
            Set(ByVal value)
                m_celsius = value
            End Set
        End Property
        Public Property farenheight()
            Get
                Return m_farenheight
            End Get
            Set(ByVal value)
                m_farenheight = value
            End Set
        End Property
    pic code
    ' Pic16f877a
    ' LCD should be connected as follows:
    '       LCD     PIC
    '       DB4     PortB.0
    '       DB5     PortB.1
    '       DB6     PortB.2
    '       DB7     PortB.3
    '       RS      PortB.5 (add 4.7K pullup resistor to 5 volts)
    '       E       PortD.7
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    '       Vo      20K potentiometer (or ground)
    '       DB0-3   No connect
    DEFINE LCD_DBIT   0
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EBIT 7
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_DATUS 50
    ADCON1=%00000111
    RST var portd.2
    DQ var portd.0
    CLK var portd.1
    pcsig var word
    'portc=0
    'trisc=0
    HIGH PORTD.3    ' Serial OUT idle state
    low rst 'reset 1620
    ' Main loop
    mainloop:
    RST = 1 ' SAA
    RST = 0
    serout portd.3,t9600,[#temp]
    serin portc.4,t9600,#pcsig
    if pcsig = 100 then high portc.5
    if pcsig = 300 then goto mainloop
    if pcsig = 200 then low portc.5
    goto mainloop
    Jul 2013
    Default Re: Sweet Sweet Successsss
    Sorry Mr. Snap...
    Can you tell me about meaning of code visual basic there line by line...
    I wanna to learn visual basic, but I'm a Beginner !!
    Please help me Mr.
  1. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 01:26
  2. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  3. PIC serial going to sleep!
    By stma in forum Off Topic
    Last Post: - 31st October 2007, 09:17
  4. PIC to serial with visual basic
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 31st March 2007, 17:06
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 5th April 2004, 00:58
