How to switch between video inputs
Results 1 to 14 of 14
    Vee have to be tied to GND or V- if you're using bipolar signal.
    If you're going to use the 4051, you will need a video amp after it.
    I actually tried it once. And was NOT happy with the results.
    Like sinoteq said, the ON resistance is too high.
    With a 1V p-p signal, I ended up with .8v p-p. Picture gets darker, and sync isn't great either.
    Not to mention the Cross-Talk, ... really bad.
    Maxim, has some very nice analog multiplexors and cross-point switches. Many are even less than 1 ohm ON resistance. No Amp required.
    http://www.maxim-ic.com/products/switches/
    Jun 2007
    Mansfield, UK
    If VEE needs to be connected to GND then why isnt it connected inside the chip?
    I dont really want to use any extra components (especially a video amp) so ill have a look at that link. I dont think it would matter too much because these are only little £12 cameras and are black and white but i was planning to have my PC and skybox plug into this circuit too and i do want the best possible picture for those.
    Im sure i saw "low resistance" in the datasheet somewhere but maybe dropping 20% is classed as "low". I suppose i could always put a resistor in the middle of a wire to test how the picture would look before buying any chips. Im sure the datasheet would specify how much resistance there is
    sinoteq's Avatar
    sinoteq Guest
    Vee is actually for signals that has both a positive and negative part. Look at a normal waveform and you can see that part of it is "under" the GND level. Vcc is feeding the signal during the positive part and Vee feeds the negative part, that would be the simple explanation. For TV this is not something to care about becasue all TV signals are on the + side of GND but to make the 4051 behave you have to connect Vee to GND. The problem with the on resistance is not really that big unless you are planning to load the camera with a low ohm (z) equipment, most TVs are 75ohm. The higher current you use in your cable the more you will loose inside the 4051. One the other hand if you want to place the camera far away from your TV for example make a CCTV system for you house it is possible you have to put amplifiers on the cameras to boost the signal if the cables get really long. How long is really long? Well that depends on how cheap your cameras are, some has really strong internal buffers and some are so weak that even the shortest cable makes things starting to fade. It is possible to make a simple video amp with a simple OP-amp so it is not that hard to fix if you later see you have a need for it.
    One more advantage of 4051, cheap... really cheap so you do not risk alot by testing them.
    Jun 2007
    Mansfield, UK
    Quote Originally Posted by sinoteq View Post
    I had noticed The problem i have is the postage is more than 10 times the cost of the chip. There is a place where i was thinking of going soon anyway who sell the chip for 5 times as much (still pretty cheap) but they said they will only sell it through their website . Im gonna have to com up with a list of things i want to make the postage worth while.
    My cameras are also very cheap and the wires are all 15 meters long. The quality isnt bad during the day but it gets a bit snowy at night when the infra-red is on. That doesnt bother me too much because im more worried about things happening in the day (kids kicking footballs at my car and putting nails around the tires etc). The only time they have to perform well in the dark is at halloween but this year im putting some green/blue lights up to help with that.
  1. Replies: 14
    Last Post: - 26th September 2007, 05:41
  2. dip switchs & inputs
    By grounded in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 13:37
  3. Newbie - 16F628A and switch latching
    Last Post: - 19th May 2006, 02:35
  4. Switch Sequence
    Last Post: - 13th February 2005, 20:36
  5. Switch Polling vs Interrupts
    By eric blair in forum General
    Last Post: - 17th October 2003, 09:38
