Perfectly!
I think i was going wrong because to me "COM" means serial. OK, i know it should be "COMM" but lots of people seem to miss off the last M. It does make perfect sense now since there are 3 address pins (2 states each) and 2^3=8 (8 inputs).
It didnt help having pins labeled "in/out" either. Just a small question on these, does that mean i could use this chip the oposite way? (1 input and 8 switched outputs)
I like the definition of "X" in the datasheet :P "Don't care"
I should have realised how it worked before because when i was at school i actually use a chip that does pretty much the same thing but it was only for LEDs.
One last question. Would i be right in saying that the grounds on the video inputs/outputs should all be connected to each other but *not* to the chip. Then the signal wires go into the correct chip pins
