Some questions regarding a servo motor's data sheet.
Results 1 to 37 of 37
    Mar 2008
    Texas, USA
    Quote Originally Posted by selbstdual View Post
    I actually was able to let the servo rotate 180°. There are mechanical elements to prevent the shaft from rotating too far. Can't they be the actual limits?
    As long as you don't run off the limits of the feedback pot. A JR digital servo I have runs off the pot before the physical limits. This is becuse JR does not use a D key on the pot shaft. Since it's digital, they assembled the servo without making sure the pot was centered and then they 'teach' the servo where center is. With the pot off center, in one direction the full movement allows the pot to run off the end. The servo then tries to run 360 degrees. The metal gears were stronger than the mechanical stop and it was broken off. On this servo this happens at .89ms.
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    In a world of german electrons
    Currently I am using gear wheels to make the 180° servo rotate a shaft 360°.
    This happens(The shaft is being stressed):
    1. Servo gets the order to drive to a position X and does it.
    2. Shaft rotates to a new position Y close to X.
    3. Shaft successfully rotates back to X.
    4. Shaft rotates to a new position Z being distant to X.
    5. Shaft is to rotate back to X but stops at a different location - in between X and Z.
    This occurs every time the shaft travels over an angle greater than 120°(60° without gear wheels).
    According to my calculations the servo's torque is high enough.
    Any Ideas of how to explain that?
    Be well - whoever you are.
    malc-c's Avatar
    malc-c Guest
    Assuming you want to control the rotation, such as a gun on a tank turrett then you could use pulleys and a standard servo. I've seen this method used on model warships to move sets of guns through a larger angular swing than a standard servo. Simply place a large diameter wheel on the servo, and a small one on the item that you need to rotate. With some maths to work out ratios, you might be able to get the result you want without having to overdrive the servo.
    For a better understanding, I uploaded a video: Here: http://rapidshare.com/files/112603057/c.avi.html which is 2 minutes long. You will need the xvid codec aswell as a mp3-codec. You should see that the part moving is almost parallel to the cam when being in position X. In software I tell the program to make the servo turn back to the old position as mentioned. But it doesn't as you can see.
    And I would like you to tell me why.
    EDIT: OR here if you prefer some service like youtube: http://www.revver.com/video/863645/problem-with-servo/
    malc-c's Avatar
    malc-c Guest
    It seems more like a code problem than hardware. Can you post the code here and let us try to work out what's happening.
    Are you refreshing the pulse width every 20 ms ? Normally you send the 1ms - 2ms pulse width to the servo every 18 - 20 ms so that the servo holds its position and via the feedback pot knows its position. It looks as if the code is not sending the pw every 20ms or that the servo is mis-reading it and losing its starting point, so on each instruction it trys to move 180 but hits the limits and thus results in limited travel.
    On a 16f628a
    @ DEVICE MCLR_OFF
    @ DEVICE hs_osc
    @ DEVICE wdt_off
    @ DEVICE lvp_off
    @ DEVICE protect_off
    Define OSC 20
    INTCON = 0
    CMCON = 7
    TRISA = 0
    TRISB = 0
    StepsRotating CON 93
    RotatingMin CON 267
    RotatingMax CON 1218
    Position VAR WORD
    PositionBefore VAR WORD
    Counter VAR WORD
    PositionBefore = 0
    LR VAR BYTE
    RotatingPos VAR WORD
    Movement VAR WORD
    ServoMotor VAR PORTB.1
    GOSUB RoutineStartingPos
    ES:
    LR = 1
    RotatingPos = RotatingMin
    ES_HS:
    ES_HS_Drehung:
    WHILE 1 = 1
        IF LR = 1 THEN
            WHILE RotatingPos < RotatingMax
                GOSUB RoutineRotate
                RotatingPos = RotatingPos + StepsRotating
            WEND
            LR = 0
        IF LR = 0 THEN
            WHILE RotatingPos > RotatingMin
                GOSUB RoutineRotate
                RotatingPos = RotatingPos - StepsRotating
            WEND
            LR = 1
    WEND
    RoutineRotate:
        FOR Movement = 0 TO 1000 / 20
            Low ServoMotor
            Pulsout ServoMotor,RotatingPos
            Pause 20
        NEXT Movement
    RoutineStartingPos:
        FOR Counter = 0 TO 1000 / 20
            Low ServoMotor
            Pulsout ServoMotor,(RotatingMax+RotatingMin)/2
            Pause 20
        NEXT Counter
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
