Analog Input on PIC16F88
Results 1 to 3 of 3
    I have a circuit where a condition can occur such that there could be 100VDC through a 10k resistor to one of the analog inputs.
    What will the "normal" voltage be? If the 100 V is just a once and awhile possibility, a voltage clamp might do the trick. Other wise a resistor network will be needed.
    And yes, 100 volt will smoke the PIC.
    Sep 2007
    USA, CA
    In my experience, exceeding the rated voltage does in fact render the a/d converter incapacitated. btdt.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Analog input on 18f252
    By kiteman in forum mel PIC BASIC Pro
    Last Post: - 12th January 2009, 09:34
  3. PORTA.4 as analog input
    By kblim in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2008, 02:22
  4. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  5. Analog pins for digital input
    Last Post: - 9th September 2005, 01:32
