Logical Operators
Results 1 to 4 of 4
    Default Logical Operators
    Can PBP support more than 2 inputs for an AND command?
    example:
    if x=0 AND y=0 AND z=0 then DoThis
    Oct 2003
    holland
    Yes PBP can do that.
    Yes, and make sure you add some parenthesis to make sure.
    IF (X=0) AND (y<8) AND (z>4) ...
    now depending where x,y,z come from, there's a few way to avoid multiple AND.
    Ok, what I'm doing is using 2 inputs for 3 switches. One connected to portb1, another to portb.2 and the last one is connected to two diodes cathodes with there anodes connected to portb.1 and portb.2. Works fine is the parentheses. Doesn't work too good without them though.
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Logical vs Bitwise ==
    By Archangel in forum General
    Last Post: - 19th February 2010, 07:22
  3. Conversion to degrees help
    Last Post: - 5th September 2008, 19:03
  4. New to PICBASIC Pro and have simple question
    By plyrathrt in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 16:26
  5. Bitwise Operators
    By SterlingY in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 06:57
