Need some advice.
Results 1 to 24 of 24
    Apr 2008
    Default Need some advice.
    Hi everyone, I'm building a device which controls temperature. Currently I'm using an 18b20 to pick up the temperature and I also have to detect zero crossing on a 50hz ac waveform on portb.0 so I can fire a triac on cirtain 0-10ms periods. I'm using a 16f628 at 4meg. it is critical that the phase controling is not interupted while gathering the temp from the 18b20 however I'm having trouble due to the time being needed to access the temperature. Does anybody know if it is at all possible to do this using the interupt on portb.0 or am I just barking up the wrong tree using this 18b20 or should I use something like a 16f88 and an lm35 with some kind of voltage ref? thanks in advanced
    Wink
    No problem ... just poll the DS data line to see if conversion has ended.
    ' Start temperature conversion
    mainloop: OWOut DQ, 1, [$CC, $44 ]
    ' Check for still busy converting ( ~ 4500 fois ... )
    waitloop:
    		INPUT DQ
    		If NOT DQ Then waitloop
    ' Read the temperature
    	OWOut DQ, 1, [$CC, $BE ]
        OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    Here, you won't have a Waitloop, but, say, goto your regulating loop ...
    AND remember heating has "a little" ( LOL !!! ) inertia, and some AC periods more or less won't disturb the system ...
    the temp data will be updated each ~ .75 s ... that's all !!!
    using a MOC 3041 to drive your SCR could miraculously simplify your program ...
    just an idea ...
    Jan 2006
    Istanbul
    From my side, I can say couple of things.
    1. If the temp resolution (and consistency) IS NOT very critical, then you can use LM35 with 12F675, and if only turn ON/OFF is on the subject (no voltage control) then you can directly fire the triac from PIC pin using zero-crossing.
    2. If temp resolution (and consistency) is critical then you can use DS18B20 with 12F675 and fire the triac from PIC pin using zero-crossing. You can check the "busy" feature so that you do not wait for temp conversation.
    In both cases, sensitive gate triacs will be more suitable for PIC's current sink (25mA max).
    If you use regular triacs, then gate will draw about 35mA, thus a MOC type will be appropriate as Alain mentioned.
    Apr 2008
    thanks for your reply s. here is a piece of software I'm using just to see if I can get it working without the flicker of when temp hits 5000 and 10000, so far failed, I'm using a moc 3021 and a bt137 and bridge with a 1k feeding porta.0 and a 10k holding it low. I have been able to make a simple dimming program so I know this hardware works, I also have an lcd so I need a few more io that a 12f675
    Define LCD_DREG PORTB
     'Set starting data bit
     Define LCD_DBIT 4 'rb4,rb5,rb6,rb7
     'Set LCD RS Port
     DEFINE LCD_RSREG portb
     'Set LCD RS Bit
     define LCD_RSBIT 3
     'Set LCD Enable Port
     Define LCD_EREG portb
     'Set LCD Enable Bit
     Define LCD_EBIT 2
     'Set number of LCD Lines
     Define LCD_LINES 2
     'Set Command Delay time in uS
     define LCD_COMMANUS 2000
     'Set Data delay time in uS
     define LCD_DATAUS 50
    temp var word
    temp = 0
    temp2 var word
    target var word
    target = 3000
    symbol fire = portb.1
    symbol ac = portb.0
    maxdelay var word
    maxdelay = 8000
    delay var word
    delay = 4000
    trisa = %00000011
    trisb = %00000001
    DQ	VAR	PORTa.0			' One-wire data pin
    temperature VAR	WORD			' Temperature storage
    count_remain VAR BYTE			' Count remaining
    count_per_c VAR	BYTE
    DS18B20_9bit CON %00011111 ; 93.75ms, 0.5°C
    DS18B20_10bit CON %00111111 ; 187.5ms, 0.25°C <-- My favorite
    DS18B20_11bit CON %01011111 ; 375ms, 0.125°C
    DS18B20_12bit CON %01111111 ; 750ms, 0.0625°C (default)
    OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_11bit]
    lcdout 254,1
    on interrupt goto firetriac
    intcon = %10010000
    mainloop:
    for temp = 0 to 10000
    if temp = 5000 then
    gosub startcon
    if temp = 10000 then
    gosub readtemp
    next temp
    goto mainloop
    disable
    firetriac:
    pauseus  delay
    fire = 1
    pauseus 10
    fire = 0
    intcon.1 = 0
    resume
    enable
    startcon:
    OWOut DQ, 1, [$CC, $44]       ' Start temperature conversion
    readtemp:
    waitloop: OWIn DQ, 4, [count_remain]	' Check for still busy converting
    	IF count_remain = 0 Then mainloop    'was this what you ment about no waiting in the 'loop
    	OWOut DQ, 1, [$CC, $BE]		' Read the temperature
    	' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    	temperature = (temperature >> 1)
    	lcdout 254,1, dec temperature / 10 ,".", dec1 temperature , " c"
        lcdout 254,192, dec delay
    Apr 2008
    what I want to do over all is to dim an incandescent light depending what temperature it is without an annoying flicker while fetching the temp.
    You may try to switch to asm interrupt or Darrel's instant interrupt to see if it works better.
    A real schematic would help...
    To generate 10uSec with PAUSEUS, you need at least a 10MHz crystal. If you're using a 4MHz, you'll need to use asm NOP or GOTO
    A scope is handy for those things. 1 channel on the Main AC, the other on the PIC output... now you see if you're really in-synch. Be careful if you do that, unless we might see some smoke messages
  1. Advice on Wiegand Buffer
    By brutc001 in forum Schematics
    Last Post: - 19th December 2009, 00:31
  2. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 27th May 2009, 23:03
  3. Your OTP advice?
    By truvahorse in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 16:37
  4. Decoding an incoming infrared signal: need advice
    Last Post: - 9th May 2008, 16:28
  5. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:21
