This is my first message in this fantastic forum, i have a problem with my pic30f2010.
I use this pic as a A/D converter, i have load on the pic an old code (because i have problem with C) so the pic transmit and recive the signal without any problems but when i enter a voltage it recognise the value and has an increase but after a few second return with it standard value (30-40mV) and i think that without a change of voltage the pic must transmit the value in entry, for example 4volt and not return on 30-40mV!!!!
Moreover when doesn't entry any voltage (0 volt at entry) the pic transmit a noise of 30-40 mV.
The problems is in the code or in my circuit??
Please help me...
I can send a scheme of my circuit and code in C if necessary...
Thanks.
