variable to equal low 4 bits of portB, and OUTPUT b4-b7
Results 1 to 6 of 6
    Mar 2008
    Thumbs up variable to equal low 4 bits of portB, and OUTPUT b4-b7
    i am putting a 4 bit binary number to portB on a 16f88. there are 8 bits on portB, and this is what i have:
    ____________________
    keyvalue var byte
    keyvalue = PORTB
    now, i want to be able to use b.4-b.7, and not make my code just a ton of if statements. i could do "if (portb.1 == 1 && portb.2 == 1 &&..........." etc, but that is kinda a lot for 9 numbers (i only need values of 1 through 9).
    basically, i want to have the high 4 bits of portB to be OUTPUTS.
    Mar 2008
    another thing.... if i could do an array, that would be fine too. i just dont know if that would help me get the high bits free for outputs....
    keyvalue var byte
    pins[1] = %00000001
    pins[2] = %00000010
    pins[9] = %00001000
    keyvalue = pins
    but i think this does the same thing and "locks" the upper 4 bits as permanent inputs.....
    TRISB = %00001111
    keyin var byte
    keyin = portb
    keyin = keyin << 4
    portb = keyin
    or like I usually do:
    TRISB=15:keyin var byte:portb=portb<<4
    but this method could present problems...
    Mar 2008
    i think i am going to try this tomorrow....
    keyvalue = portB & $0F 'bitwise 00001111
    trisB.7 = 0
    XXXXXXXXXXXXXX
    trisB.7 = 1
    on a side note, i was namely trying to emit sound on the "sound" command... since it can only be done on portB, and so i tried to dot he sound command, and it worked. on the plus side as well, the speaker is grounded so it was a convienient "pull-down"
    Jan 2006
    Istanbul
    May be something like this could help you.
    <font color="#000080"><i>'============== Name Pins =================
    </i></font>A <font color="#000080"><b>VAR </b></font>PORTB.<font color="#FF0000"><b>7
    </b></font>B <font color="#000080"><b>VAR </b></font>PORTB.<font color="#FF0000"><b>6
    </b></font>C <font color="#000080"><b>VAR </b></font>PORTB.<font color="#FF0000"><b>5
    </b></font>D <font color="#000080"><b>VAR </b></font>PORTB.<font color="#FF0000"><b>4
    </b></font>MyPort <font color="#000080"><b>VAR BYTE
    </b></font>MyPort <font color="#000080"><b></font>=<font color="#FF0000"><b> 0</b>
    </b></font>Loop:
         <font color="#000080"><b>GOSUB </b></font>SetPins
         <font color="#000080"><b>IF </b></font>MyPort = <font color="#FF0000"><b>2 </b></font><font color="#000080"><b>THEN </b></font>SayHello   <font color="#000080"><i>' Example to use pin assignment.
         </i><b>GOTO </b></font>Loop
    SayHello:
          <font color="#000080"><b>LCDOUT </b></font><font color="#FF0000"><b>$fe</b></font>,<font color="#FF0000"><b>1</b></font>,<font color="#008000"><b>&quot;HELLO&quot;
          </b></font><font color="#000080"><b>PAUSE </b></font><font color="#FF0000"><b>1000
          </b></font><font color="#000080"><b>GOTO </b></font>Loop
    SetPins:
        MyPort.<font color="#FF0000"><b>0 </b></font>= A
        MyPort.<font color="#FF0000"><b>1 </b></font>= B
        MyPort.<font color="#FF0000"><b>2 </b></font>= C
        MyPort.<font color="#FF0000"><b>3 </b></font>= D
        <font color="#000080"><b>RETURN
    </b></font>
    Quote Originally Posted by reaper0995 View Post
    Why is it limited to Port B?
  1. PIC16F877A for application in mobile robot...
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 15:47
  2. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 00:21
  3. Microcontroller with 2 way paging application problem
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
