Eventually I moved the data lines on PORTC and voila, the LCD is displaying characters as it should. Thank you guys for the help.
Here is the working code:
Code:' display a message on the lcd '--- defines DEFINE OSC 8 DEFINE LCD_DREG PORTC ' portb is the port used for data lines DEFINE LCD_DBIT 4 'the pin on port connected to LCD pin DB4 DEFINE LCD_RSREG PORTA 'pic port used for the RS line DEFINE LCD_RSBIT 4 ' port pin where RS pin is connected DEFINE LCD_EREG PORTB ' PIC port where E pin is connected DEFINE LCD_EBIT 3 ' port pin where E pin is connected DEFINE LCD_BITS 4 ' 4 bit mode DEFINE LCD_LINES 2 ' 2 LCD lines DEFINE LCD_COMMANDUS 2000 'delay between LCD commands DEFINE LCD_DATAUS 50 'delay between data sent '--- register configs adcon1=$0F ' all digital i/o trisb=0 ' portb all outputs trisa=0 'porta all outputs trisc=0 intcon2.7=0 ' enable pullups osccon=$70 ' oscilator configure '--- main program PAUSE 1000 ' pause to let the LCD initialise repeta: high portb.0 ' light led to see when main loop is running LCDOUT $fe,1 ' Clears LCD LCDOUT $fe,2, "hello" ' Returns to beginning of line 1 and writes "string" LCDOUT $fe, $C0, "world" ' line 2 pause 1000 ' pause to see it goto repeta ' do this forever
