code size VS speed optimization setting?
Results 1 to 8 of 8
    Perth, Australia
    Default code size VS speed optimization setting?
    Does PBP have a code size vs. speed optimization setting? I know some compilers have this option but I wasn't sure about PBP.
    Basically i need the compiled code to be as small as possible, but execution speed isn't overly critical.
    Is there a setting for this?
    I have never heard of a setting like for that. I think it all depends on the person using the keyboard.
    Small code is done with many sub routines. Say you are using an ADC. If you need to read the ADC many times, have a GOSUB or GOTO a LABEL with everything in that routine instead of rewriting it several times. If that routine has five lines to read the ADC and write it to EEPROM or some place else, then the one GUSUB here and there will end up saving some lines of code. In other words, do not repeat yourself.
    HTH
    Perth, Australia
    yeah ive written a program nearly 3000 lines long, and ive hit the end of the 32k of code space my PIC has. I pulled all the strings out into EEPROM and that saved some space, but im likely to run out again soon. I've done the most obvious things to save space.
    *edit* i guess the only thing left to do is go thru all 3000 lines looking for where i can make it more efficient... *sigh* that will be a chore
    Just a thought...
    Move some of the routines over to another PIC, Maybe something that has some heavy calculations. PIC#1 sends data to PIC#2 for calcs, when finished PIC#2 sends data back to PIC#1. Sort of like an interrupt.
    Quote Originally Posted by Kamikaze47 View Post
    Have you tried moving the most commonly used variables to BANK 0? (only applies if you're using a 16Fxxx series PIC, doesn't do anything on an 18Fxxx series)
    Perth, Australia
    using an 18F4550
    I would just get a pic with more code space. but i need the USB functionality of the 4550.
    using an 18F4550
    Repeat...Until uses less space than a For...Next, about 3 bytes for each one...
    Multiplies and Divides by power's of 2 can be replaced by shifts << and >> ...
    For...Next loop that are (for instance) "0 to 7" take up less space than "1 to 8", again, only a few worth...
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 09:02
  2. Problem runing my code
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 20:36
  3. Making Program Code Space your playground...
  4. pic18F code size problem???
    By dogi in forum mel PIC BASIC Pro
    Last Post: - 7th March 2005, 21:52
  5. Need help, high speed D/A converter, see code
    By rpatel in forum mel PIC BASIC Pro
    Last Post: - 20th December 2004, 01:33
