2 PWM in 16F690 problems
Results 1 to 10 of 10
    Apr 2008
    Default 2 PWM in 16F690 problems
    I am working in a 2 DC motor control project. I'am making tests with the HPWM in a 16F690, but i'm having problems to generate 2 diferent signals... I generate without problems a PWM signal in the channel 1, but i can't drive a signal in the channel 2..
    I need to know if its possible to drive 2 diferrent dutty cycles in the channel 1 and 2, and how to do this.. I'am using Microcode studio and picbasic pro..
    This PIC have only 1 CCP channel, which mean you can't use HPWM for more tha 1 channel. If you need another channel, there's serveral way to do it: Change your PIC for one having 2 CCP module, or keep the existing one but create a Timer interrupt based PWM, or do the same in a tight loop... but you will be limited to do anything else, or Darrel Taylor's Multi_SPWM routine ( http://www.pbpgroup.com/modules/wfse...p?articleid=12 ).
    Depending your DC moto spec.. the Timer based or else low frequency PWM may work... or not. HPWM will produce higher frequency and run in background.
    Apr 2008
    Thankyou for your fast answer.. can you recommend me a mid range micro that can be used on this application?, dont you know if any dip 20 pin have 2 ccp modules? These will be a critical application so I need to do it with HPWM.. not with software..
    As far as i remember, the smallest one with 2 CCP have 28 pins.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by ciendavila View Post
    If you are willing to step up to the 18F family, I believe there are a couple of 18 pin options (e.g., 18F1230 and 18F1330).
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    problem with most single ECCP module is that you're restricted with only 1 duty cycle... but many output type, half-bridge, full-bridge etc etc.
    But yeah, Microchip have tons of PIC model, i just didn't found one Flash type with 2 CCP under 28 pins. Sure there's chance that i missed a couple of models.
    Apr 2008
    I already find a solution, as you say 18F1330 looks like the best model for PWM aplications. It have 18 pins and ADC, perfect for my project, but the microcode doesnt works with it as well as the other micros, when you try to use the HPWM, many errors occur..
    I have been working on the project today, and finally it works, working directly with the registers, you can drive 3 different PWM at the time.
    Lets see how the ADC works and if i can finish my project without any other problem.
    Thankyou for all..
  1. 12F683 2 x PWM Outputs
    Last Post: - 23rd July 2021, 20:20
  2. 16f877 generate pwm according 2 analog input
    By madxice in forum mel PIC BASIC Pro
    Last Post: - 9th July 2009, 14:47
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  5. Variable PWM on 2 Channels using software.
    Last Post: - 23rd September 2006, 01:34
