SERIN from a large string
Results 1 to 6 of 6
    Jan 2007
    Houston, TX
    Red face SERIN from a large string
    Hello again,
    I have a nifty project where I am taking in a data string from a "black box" we'll call it for now, and I only want one peice of data from the string.
    I have attached a few samples of the string.... from my hyperterminal I figured out that the black box is sending out data at 9600 8N1 around 10x a second.
    DEPTH 250.0 Ft SPEED 0.0 F/mTENSION 0 Lb
    Here is the deal, All I want to store from this data (into a variable) is the depth...250.
    That's it, I only need the first 3 sigfigs, I don't need speed or tension.
    Here is how I think I will handle this.....
    D0 var word
    SERIN PORTA.?, N9600, ["DEPTH", D0]
    Depth will be my qualifier, I am not sure if the depth is being sent from the blackbox as one word, or a byte per digit (character)???
    How can I not take in the rest of the data until the qualifier is met again?
    Am I on the right track?
    thanks for any help
    Padawan-78
    Jan 2007
    Houston, TX
    OK,
    looks like I need to use the more powerful SERIN2 command,
    I have not had a chance to try it yet, but I am moving more towards something like this....
    SERIN2 PORTA.?,84,[SKIP 5,DEC5 B0]
    I need up to 5 decimal places for my depth as my tools can go 20,000+ feet underground
    Padawan-78
    NAH.
    SERIN would work, SERIN2 too and so DEBUGIN a well.
    SERIN2 ..... [wait ("DEPTH "), DEC3 WordVariable, SKIP 1, DEC1 ByteVariable]
    Or use an array and remove the dot... there's some danger here... what the string looks like when you receive 20,000.0 Feet?
    About now?
    Jan 2007
    Houston, TX
    You placed a space after depth, is this necessary?
    As are spaces in a string considered characters?
    if so....
    What if the space between depth and the MSF changes depending on depth?
    Also, I think there may be some space between DEPTH and the left screen on my hypterminal....this space changed depending on when I disconnected and reconnected the terminal to the black box.
    Padawan-78
    You could still wait for "DEPTH" and receive an array of x character... then you just need to parse your character one by one. If one in the list is not a decimal number, you just remove it.
    And yes, space is a character, i've never tried with space before DEC, in theory it has to work, but for sure, the decimal point will cause some problem using DEC modifier.
    Jan 2007
    Houston, TX
    Talking
    Steve,
    You were totally right!
    I was using 84, instead of 16468, after my pin,
    that's what was hanging up my program.
    Now everything is working great!
    thanks a 10^100,000
    Padawan-78
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 12:53
  2. String Seperation
    Last Post: - 30th November 2007, 19:32
  3. serin string question
    By Sam in forum Serial
    Last Post: - 2nd December 2006, 21:29
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 04:39
  5. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 19:02
