Help LCD
Results 1 to 5 of 5
Thread: Help LCD
    Puerto Rico
    Exclamation Help LCD
    My Controler (Pic18f2620)
    I am Sending Data from one Pic to my LCD with Other Pic but is no Working..
    SerOut LCDScreen, T9600,[LCDCmd,LCDLine1," TEST "]
    is not displaying nothing
    LCD Code (pic16f688)
    INCLUDE "modedefs.bas"
    OSCCON=$70
    DEFINE OSC 8
    define LCD_DREG PORTC
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 0
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    BO VAR byte
    ANSEL=0
    CMCON0=7
    LOW PORTA.4
    LCDOUT $FE,1,"LCD 2.0v" (Work ok)
    HIGH PORTA.2 'Back LED
    LCDStart:
    serin PORTC.5,T9600,BO (no Wotk)
    lcdout BO
    goto LCDStart
    My Hobbies is PicBasic PRO
    Did you tried with a slower baudrate like 2400 bauds?
    on the Pic18f2620 side, which osc speed are you using?
    Are you sure LCDScreen pin is not an open collector type?
    any chance to see some code snip of your PIC18F2620 side?
    When you say nothing work... you mean absolutely nothing.. not even some garbage character?
    Puerto Rico
    Exclamation
    Yes it work the lcd but all character i send to lcd does not respond
    the only i see is black blocks.
    Jan 2006
    Istanbul
    Seems to be a contrast issue to me.
    Could be... but it doesn't explain why the first LCDOUT works huh? Well that's what my half-smart brain tell me
    I feel a baudrate issue, timing issue... never dared to calc the amount of time required for a LCDOUT and to receive a BYTE though. I may try it... later
    I tend to use USART so far... this 2 bytes buffer is often handy...
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
