connecting a 4X4 keypad
Results 1 to 7 of 7
    Whatever the PIC you're using, you can use almost every I/O on it. The software must be done to work with your own assignment. Not much.
    PIC16F877A have internal pull-up which can be enable by software... but they're on PORTB ONLY. No problem if you don't need any feature available on PORTB. Just hook your keypad on PORTB, use
    OPTION_REG.7=0 ' Enable internal pull-up on PORTB
    and away you go.
    Explanation of pull-up.
    http://www.seattlerobotics.org/encod...97/basics.html
    By the kind of question you've asked, it looks like you're not too experienced with PICs. Yes, 16F877 is fine, if you checked you'd discover it has a PORTB and if you look at the Datasheet (which you can freely download from the Microchip website - and is a MUST!!!) you will discover that PORTB on that PIC also has pull-up's. All a pull-up is, is a Resistor internal to the PIC, which you can program the PIC to switch-in if you need it. That Resistor connects between the relevant PIC pin and Vdd (+ve supply rail) pulling that pin up to +ve (hence the name). Just saves you having to provide one externally.
  1. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  2. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  3. 4x4 Keypad and LCD sharing port B
    By msnm4 in forum mel PIC BASIC Pro
    Last Post: - 9th May 2008, 09:13
  4. I2C PCF8574 4X4 Keypad routine
    Last Post: - 28th January 2007, 22:25
  5. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 04:54
