Measuring voltage from a current transformer
Results 1 to 15 of 15
    Jan 2006
    Ok,
    It took me a while to grasp, but I think I got it now.
    I had to bring up schematics to figure it out, but a resistor needs to be placed across the secondary leads of the CT. This was the magic thing that I didn't get at first.
    Now your formula makes some sense.
    Primary current max to sense - 20a
    Transformer ratio 1000:1
    5v/.02=250ohm
    I only had a 275 to test with, but got some results with a voltmeter.
    when running a 25w light bulb, it read .062v
    100w light bulb read .224v
    question is, from my voltage reading, how to I calculate back to the primary amperage?
    ---edit---
    I think i figured this part out. A=(V*20)/5 or A=V*4
    ---end edit---
    also, I will need rectifier to go from AC to DC. Do you have any schematics that would be appropriate for low voltage AC to DC?
    If the load will always be resistive, like light bulbs or heater elements then a "precision rectifier" and a simple linear equation will do the job.
    If there are inductive loads, the resulting waveform will not be a sine wave, and you'll need to do an R-M-S conversion. Almost impossible with a PIC, unless that's the only thing the PIC is doing.
    There are several RMS converter chips available that give a DC output so you can use a linear equation again. I like the LTC1966, but that's just because it's the only one I've figured out how to use. I'm not good with hardware.
    Jan 2006
    Loads will be anything that can be plugged into a 120v plug.
    Most common will be lights, heaters, computers, other electronics, etc.
    whats the difference between a precision rectifier and a full wave bridge rectifier? lemme guess, precision ..heh
    last thing. I am good at getting things done once I have a detailed parts list. The circuit explains what what kind of resistors and op amps to use, but no specs on the diodes. Digikey carries ~10,000 varieties.
    Quote Originally Posted by docwisdom View Post
    Refrigerators, Sump Pumps, Compressors, Fans ...
    They can all be plugged into a 120V outlet. And they would all be considered "Inductive Loads".
    So you can forget about the Precision Rectifier.
    Check out the datasheet for the LTC1966
    At the bottom of the sheet in the "Typical Applications" | Single Supply RMS Current Measurement
    Shows exactly what you need.
    Added: Although you might want to increase the "Burden" resistor. 4mv/amp is hard to read with a PIC's A/D.
    Dec 2005
    Toss the current transformer in the junk bin and get a hall-effect current sensor ffom Allegro Microsystems.They have high isolation, handle AC or DC, come in a wide range of current capacities, output a DC voltage proportional to current, and are rather inexpensive.
    Jan 2006
    i would, but as i mentioned in previous threads, i need for it to not interfere with the primary path. the hall effect devices require you to break the primary path and route it through the IC.
    DT, just to satisfy my natural curiosity. what effect will you experience if you were to have an inductive load on the primary with a precision rectifier on the secondary?
    You would get the wrong amperage reading.
    If you calibrated the device with a resistive load, so that it reads the correct current with light bulbs etc. When you plug in an inductive load like a motor, the readings will be much lower than they should be. They will vary from one inductive load to the next. And even the same load at different current levels will be in error by different amounts.
    If you plug in a Light Dimmer, Motor Soft-Start or speed control, The thing will go absolutely NUTS from the "Chopping" of the SCR or Triac.
    All of those problems are resolved by using the RMS converter. Which gives the correct amperage under ALL conditions.
  1. ADC input using a current transformer?
    Last Post: - 12th May 2009, 23:13
  2. Monitoring voltage and current ?
    By iugmoh in forum General
    Last Post: - 1st April 2009, 12:39
  3. Measuring DC current
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 19:49
  4. Measuring Battery voltage
    Last Post: - 4th December 2006, 00:07
  5. measuring current from a photo diode
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th November 2005, 15:42
