Searches
Results 1 to 12 of 12
Thread: Searches
    This will significantly increase the Search Database size as the way the search works it indexes every word used rather than scan the entire database sequentially. This means that every three letter word gets indexed, so you have to waste half a day of your life telling it not to index 'the' and 'vcc' and 'vdd' and 'and' and 'etc' etc etc and every other three letter word that's irrelevant. Ultimately it's Lester's decision as it's his Server that ends up getting clogged.
    Italy
    Try Google.
    rc5 site:www.picbasic.co.uk/forum
    Or, even better: (use "")
    "rc5" site:www.picbasic.co.uk/forum
    Luciano
    Post
    Ok, if all searchable words needs to be indexed manually, i certanly understand why it's not practical to include short searches. However i still feel that it makes the searchfunction alot less useful since most abbreviations are two or three letters long(or short). May i suggest that the database could include three letter words if they were written in CAPS, that would include most pic related abbreviations, but leave "and", "the" and similar words.
    Luciano.
    The Google works better than i thought, thanks. However "rc5" or "RC5" doesn't work(i already tried it), and after Melanies explanation i understand why.
    Cheers
    /Ingvar
    Italy
    On my computer Google returns 109 results when I enter
    "RC5" site:www.picbasic.co.uk/forum
    "rC5" site:www.picbasic.co.uk/forum
    and returns the same 109 results when I enter
    RC5 site:www.picbasic.co.uk/forum
    rC5 site:www.picbasic.co.uk/forum
    (Click again the button "Search" if you get less/more results).
    Try that:
    a site:www.picbasic.co.uk/forum (26,000 results)
    ad site:www.picbasic.co.uk/forum (812 results)
    add site:www.picbasic.co.uk/forum (308 results)
    addi site:www.picbasic.co.uk/forum (0 results)
    addit site:www.picbasic.co.uk/forum (0 results)
    additi site:www.picbasic.co.uk/forum (0 results)
    additio site:www.picbasic.co.uk/forum (0 results)
    addition site:www.picbasic.co.uk/forum (692 results)
    "a" site:www.picbasic.co.uk/forum (26,000 results)
    "ad" site:www.picbasic.co.uk/forum (812 results)
    "add" site:www.picbasic.co.uk/forum (308 results)
    "addi" site:www.picbasic.co.uk/forum (0 results)
    "addit" site:www.picbasic.co.uk/forum (0 results)
    "additi" site:www.picbasic.co.uk/forum (0 results)
    "additio" site:www.picbasic.co.uk/forum (0 results)
    "addition" site:www.picbasic.co.uk/forum (692 results)
    Try the same without "site:www.picbasic.co.uk/forum"
    ad (477,000,000 results)
    add (1,150,000,000 results)
    addi (7,100,000 results, Google returns results like addicting)
    addit (497,000 results)
    additi (146,000 results)
    additio (156,000 results)
    addition (782,000,000 results)
    "ad" (475,000,000 results)
    "add" (1,020,000,000 results)
    "addi" (6,720,000 results)
    "addit" (496,000 results)
    "additi" (146,000 results)
    "additio" (156,000 results)
    "addition" (749,000,000 results)
    Conclusions:
    The use of "" does not make any difference if the searched
    string is followed by "site: ...." .
    Example:
    or
    will return the same 109 results.
    Luciano
    Nov 2004
    Fribourg, Switzerland
    Default Quotes
    Just to to explain one thing in google's search:
    When you use quotes "" means that if you have more than a word and both come together, google will search for both words in the same order you've typed.
    Imagine you know a thread's name but you don't want to scan all the pages looking for it. just type it between quotes and it will come in all flavors: Single post, thread, threads index...
    Try this:
    "Conflict receiving RS485 stream" site:www.picbasic.co.uk/forum
    it will come 23 links, all about the subject.
    Hope this help
    Hans
    Italy
    Quote Originally Posted by hmr
    Yes, correct but the use of quotes works also with single words.
    If you search:
    addi
    Google returns 7,100,000 results and you will see also addicting in the results.
    If you search:
    "addi"
    Goggle returns 6,720,000 results and you will not see addicting in the results.
    Luciano
    Luciano.
    I thought you meant - do a search for "rc5" on www.picbasic.co.uk/forum, i guess i got confused by the fact that it turned up as a link. Next time i'll try to look at ALL the information in the post.
    Thanks.
    /Ingvar
    Nov 2004
    Quote Originally Posted by Luciano
    If you search:
    addi
    If you search:
    "addi"
    Luciano
    Hi Luciano,
    That's right it also works with single words and I never said it didn't.
    In fact when you put a single word between quotes the search engine will treat it as a hole word and will not show results as part of a word as in your example addi as for addition or addicting.
    Another interesting feature of the search engine is that if you search for 2 words and want that both are int the result you just have to put a + sign immediatly before the words.
    Hans
