Problem with AD inputs at PIC16f873a
Results 1 to 4 of 4
    Jul 2007
    Default Problem with AD inputs at PIC16f873a
    I have a problem with a Pic16f873a.
    I´m using 4 of the 5 analog to digital converts. Every AD port is with a resistor pulled down.
    On Port c I have 4 outputs with LEDs.
    As you can see on Beispiel1.bas I read ad channel 0 to 3 and when there is a value bigger than 0 the Led on the output changes to high.
    This works for all of the 4 channels.
    Now I`ve changed the program (see Beispiel2.bas)
    On AD channel 0 the Led only get high when on the input a signal with 2.5V exists.
    Now, when I put a signal bigger than 0V on any of the 4 AD inputs, all of the 4 output Led gets high.
    I can´t understand this. I´ve tried various ADCON0 and ADCON1 and Sample-times without any other result.
    Does somebody know, what here is wrong?
    Best regards,
    Thorsten Wurm
    Maybe
    IF Messwert1 > 120 then check
    check:
    IF Messwert1 < 130 then
        high Alarm1
    Jul 2007
    hi,
    I´ve trie this, but the problem is still the same.
    I think the main program is correct and there
    only can be some errors in the configuration and the adcons.
    Best regards,
    Thorsten Wurm
    You might be correct, I have not looked at the data sheet for that chip lately.
    Read this article. http://www.rentron.com/PIC12C67XAD.htm
    It is for a different chip but it explains how to set up the ADC much better than I can.
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 22:22
  3. ADCIN - AD settings are wrong
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 4th December 2006, 17:32
  4. problem RB4-7 on a 18F876A
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 30th March 2006, 15:30
  5. ADC problem
    By NacNud in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 03:27
