pic12F683 , gpio.5 not accessible...
Results 1 to 17 of 17
Threaded View
  1. #8
    Jul 2007
    Red face
    ohh you got a point here!
    Modified the __config line and it's definitely using it...
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    but then I get
    ICDWarn0033: MPLAB ICD 2 does not support programming this device if both the internal oscillator and internal MCLR are selected. You may continue programming, but you are encouraged to cancel, reconfigure your device, and try again.
    ICD0200: Operation Aborted (Warning 32).
    so basically I assume I cannot have all pins as digital IO.
    still It's better for me to set MCLRE on and get GPIO.4/5 working, and leave MCLRE pin alone.
    Unless there's a way to bypass this...
    It's also great to know which compiler i"m using LOL
    edit: setting MCLRE_ON I can get access to GPIO 4 and 5 now..
    Still I wonder if it's possible to get rid of MCLR
  1. Programming Problem PIC12F683
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2009, 22:39
  2. pic12f683 being picky about pins...
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 00:16
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 13:47
  4. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 06:44
  5. PIC12F683 Pinouts?
    Last Post: - 17th March 2006, 00:56
