pic12F683 , gpio.5 not accessible...
Results 1 to 17 of 17
    If you're using Instant Interrupts, the program has to be assembled with MPASM.
    Hi Darrel,
    I thought he was as he did not report any compiler errors, doesn't PM choke on DT_I.I.?
    Yes, PM will definately "choke" on Instant Interrupts.
    What I'm saying is that ... since it appears he's using MPASM, he's looking at the wrong configs.
    Jul 2007
    Red face
    ohh you got a point here!
    Modified the __config line and it's definitely using it...
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    but then I get
    ICDWarn0033: MPLAB ICD 2 does not support programming this device if both the internal oscillator and internal MCLR are selected. You may continue programming, but you are encouraged to cancel, reconfigure your device, and try again.
    ICD0200: Operation Aborted (Warning 32).
    so basically I assume I cannot have all pins as digital IO.
    still It's better for me to set MCLRE on and get GPIO.4/5 working, and leave MCLRE pin alone.
    Unless there's a way to bypass this...
    It's also great to know which compiler i"m using LOL
    edit: setting MCLRE_ON I can get access to GPIO 4 and 5 now..
    Still I wonder if it's possible to get rid of MCLR
    Hmmm, It must be a limitation of your programmer.
    I just tested it here with a 12F683 and an meLabs U2 programmer.
    It works fine with the internal oscillator and MCLR either ON or OFF.
    Jul 2007
    humm, it means ICD2 (clone) is less powerfull/featured than yours...
    would never expected that!
    or maybe I can try to let it program the chip anyways, and see what happen.
    i'll try it tonight.
    Thanks for testing
    Maybe be not less powerful... but has it's own way to work. ICD2 is more a debugger than a programmer. Melabs's one is a Programmer, period.
    Cheap alternative.. the endless Microchip's PICKIT 2 suggestion.... which can also be used as a debugger on some PIC.
    Jan 2006
    Istanbul
    Flipper,
    How did you set your OSC to work internally at 8Mhz?
    OSCCON = %01110000 ' Internal 8MHz osc set speed
    I think, it should be OSCCON = %01110001
    Did you notice that?
  1. Programming Problem PIC12F683
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2009, 21:39
  2. pic12f683 being picky about pins...
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 26th March 2009, 23:16
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 12:47
  4. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 05:44
  5. PIC12F683 Pinouts?
    Last Post: - 16th March 2006, 23:56
