Oscillator stops when touching with a wire
Results 1 to 24 of 24
    Pull-up or pull-down resistor is an easy to test Solution?
    Sep 2003
    Vermont
    It sounds like static electricity is the culprit here. I understand touching an input, but the ground should be somewhat immune to the phenomena. It sounds like there is a ground loop in the connections. Look for multiple lines connected to ground in the same run of cable. Touching one will cause an imbalance. So if the shield is connected to ground, and another line in the cable is, this could cause a problem. The simplest fix is to not connect the shield on one end of the cable. While it sounds counter intuitive, it might be the cause, or one of them.
    Ron
  1. 1 Wire Search Routine
    By Dave in forum Code Examples
    Last Post: - 4th March 2016, 08:39
  2. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 03:30
  3. 24c16 vs 24lc256 and serial wire identification
    By inspired4real in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 18:37
  4. Looking for low Wattage heater wire
    By jmgelba in forum Off Topic
    Last Post: - 21st November 2005, 19:22
  5. RPM with wire and PIC
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 14th December 2004, 21:42
