Oscillator stops when touching with a wire
Results 1 to 24 of 24
    Quote Originally Posted by Wilbert Ingels View Post
    Good evening all,
    I've made a RS485 network of 16 remote devices (16F886) and 1 master (18F2620) all running Picbasic pro. Everything runs perfectly, however, when i touch the ground or one of the inputs with a non connected wire (to connect an input with the ground for example), the clock stops running (wire is only connected on one side).
    I've tried to change the capacitors of the xtal (changed it between 15pf and 22pf) but the result remains the same.
    PIC's are configured in HS mode.
    Any ideas how to solve this?
    Many thanks !!
    Wilbert
    How about decent cap's across Vdd and Vss?
    Do you have a pull up on MCLR?
    AND
    1.make sure LVP is set to OFF on both
    2.make sure ALL Vss & Vdd are connected.
    If both run @5V, it shouldn't be a Brown-Out reset or... sort of.
    Thanks for the replies !
    Just to come back on the below feedback:
    - Caps are used to stabilize power supply (100nf and 10mf) and also every PIC has a 100nf cap on the power supply pin
    - MCLR has a pull-up resistor
    - LVP set to off
    Other ideas what it could be?
    I can post the network drawing (Eagle file) but i'm not sure if i can attach files ...
    Many thanks for helping me with this !!
    Wilbert
    Also the 2 VSS pins are connected ...
    How good / stable is you power supply?
    Some additional information:
    - The processor doesn't reset but stops in my opinion. I've used debug information on a serial port. On each startup, an appropriate message is sent (which i don't receive when this problem occurs). I'm also displaying variables and when the processor continues, he still has the right values.
    - Most of the cases, information on the RS485 network triggers the processor to continue.
    Dave,
    Good point, it's a lab power supply so i didn't had any doubt about it ... I'm going to check it now !
    Thanks !
    Wilbert
    And how is the brown out fuse set?
    Checked Power supply -> OK
    Added additional caps -> problem remains
    Changed Power supply -> problem remains
    Changed cables -> problem remains
    Even when i touch VDD with a none connected cable (15 cm), i see the clock stopping on multiple processors ...
  1. 1 Wire Search Routine
    By Dave in forum Code Examples
    Last Post: - 4th March 2016, 08:39
  2. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 03:30
  3. 24c16 vs 24lc256 and serial wire identification
    By inspired4real in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 18:37
  4. Looking for low Wattage heater wire
    By jmgelba in forum Off Topic
    Last Post: - 21st November 2005, 19:22
  5. RPM with wire and PIC
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 14th December 2004, 21:42
