Oscillator stops when touching with a wire
Results 1 to 24 of 24
Threaded View
  1. #18
    Why not "SERIN" all of your characters into a 'sliding buffer string' and keep that in a tight loop. You can keep track of it and keep checking if the beginning of that 'sliding buffer string' contains the "ST" that you're looking for. When it does, you save the data and act on it accordingly.
    That way, you should be able to avoid the timeout and glitch problems that you're having.
    I thought I had a good idea for you...lost it...can't find it again
  1. 1 Wire Search Routine
    By Dave in forum Code Examples
    Last Post: - 4th March 2016, 07:39
  2. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 02:30
  3. 24c16 vs 24lc256 and serial wire identification
    By inspired4real in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 17:37
  4. Looking for low Wattage heater wire
    By jmgelba in forum Off Topic
    Last Post: - 21st November 2005, 18:22
  5. RPM with wire and PIC
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 14th December 2004, 20:42
