Simple LCD code not working..
Results 1 to 8 of 8
    Dec 2007
    Default Still not working
    Thanks all for the replies.. I originally had the TRISB = 0, but removed it to simplify, added it back in, no difference. Added the cammandus & dataus lines, still no difference.
    I'm using the 16F84a for now, so no A/D, no LVP, I've made sure it has XT OSC.
    And have fiddled the contrast pot, I know it's right now tho, as the blocks come up on the first line, and then when I LCDOUT $fe,1.... The screen clears.
    I even measured continuity between the data pins on my pic, and the pins on the LCD incase I had a problem on my breadboard.
    I think I'm going to have to get another LCD panel to rule that out as being the problem...
    Any more suggestions I'd be happy to hear, but I now presume it's a hardware fault, seeings how it doesn't seem I stuffed up any of the code.
    Thanks again,
    edit - R/W is also tied low... I know this as when I first connected it, I tied it high, and nothing happened, when I tied it low, it now clears...
    Dec 2007
    Default Fixed It
    Just a follow up...
    I got another LCD the same, connected it, it came up with crazy characters on the screen... In desperation I swapped the cable I was using (IDE HDD cable) and low and behold it works.
    On closer inspection, the cable I was using originally, has more conductors in it than pins on the plug. I pulled the plug apart, and there is a big copper bus-bar that connects certain pins to each other, and also I assume to ground. Must give some kind of shielding effect.
    Anyway all sorted.
    Thanks to everyone that helped...
    Cheers
    Quote Originally Posted by davewanna View Post
    Info you: Older IDE cables had 40 pins, newer ones have 80 pins, 40 normal + 40 grounds/shields, for use with the higher DMA speeds and transfer rates in the newer ATA spec's.
  1. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  2. Loop with two motor and 2 sensors
  3. My LCD code is not working...
    By kvrajasekar in forum mel PIC BASIC
    Last Post: - 7th December 2008, 06:41
  5. LCD issue with EasyPIC5
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 15th June 2008, 10:17
