Manipulation of string array
Results 1 to 5 of 5
Threaded View
  1. #3
    Apr 2008
    Post
    Thanks for the reply Ron.
    I have tried to print out 38 from the string which I can if I use
    SEROUT2 portb.2,84,[LAT[0],LAT[1],10,13] ' PRINTS OUT 38 FROM THE STRING (3810.7890)
    IF I GO
    DEGLAT = LAT[0] * 10 + LAT[1] 'DEGLAT IS DEFINED AS DEGLAT VAR BYTE
    I would have thought I would have got an output of 38 when I used the following
    ' Instead I got 36
    If I use the following:
    DEGLAT = LAT[0] ' (DEGLAT) IS DEFINED AS (DELGAT VAR BYTE)
    I = LAT[1] ' (I) IS DEFINED AS (I VAR BYTE):
    SEROUT2 portb.2,84,[DEGLAT,I,10,13] ' I get 3€ Instead of 38
    Thanks Benny007
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Replies: 1
    Last Post: - 28th January 2010, 23:15
  4. String Manipulation
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 8th April 2008, 15:39
  5. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
