What's the voltage on output pin when it's HIGH?
Results 1 to 17 of 17
    Feb 2003
    also cant see what the code is meant to achieve because irrespective of whatever value you have for pausetime the led will alsways be at 50% brightness as the on and off times are the same.
    If you are trying to get a variable brightness then with pausetime being 0-255 you should have something like
    adcin 0, timeVar
    pauseTime = timeVar / 12
    high portb.7
    pause pauseTime
    low portb.7
    pause (255-pauseTime)
    which will give a total time of 255 but the on will vary from 0-255 whilst off will also change from 255-0
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Apr 2006
    Yes, you're right. The on-off time is too fast for the meter to register.
    I am just trying to achieve a TTL pulsing; 5V, 0V, on/off at different rates. The LED was put in there just for a visual reference, it's not part of my finished circuit.
    The purpose of this pulsing of the pic pin is to replace a Schmitt Trigger Pulse Oscillator.
    It is working the way I expected "in circuit", but I was just wondering why I couldn't read discreet 5V and 0V on my meter, (taking reading on the bare pin, not resistor or LED).
    If I had an Oscilloscope I guess I would see the TTL (I would see the square wave pulse).
    I'm starting to see the benefits of an Oscilloscope...
    Thanks for all the help, I appreciate it very much.
    T
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Microcontroller with 2 way paging application problem
  4. Serious Serial Situation Setbacks...
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
