What's the voltage on output pin when it's HIGH?
Results 1 to 17 of 17
Threaded View
  1. #7
    Apr 2006
    Yes, with the resistor and LED disconnected, I still read 2V out of the portb.7
    'DEFINITIONS'
    DEFINE OSC 20
    DEFINE ADC_BITS 10        ' Set number of bits in result
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 15
    'PORT SETUP'
    TRISA = %11111111       'set up all pins on portA as input pins
    ADCON1 = %10000010      'Set PORTA analog conversion and right justify result
    timeVar   var word
    pauseTime var byte
    adcin 0, timeVar
    pauseTime = timeVar / 12
    high portb.7
    pause pauseTime
    low portb.7
    pause pauseTime
    I'm using the pic like this to provide a TTL pulse, (replacing a Schmitt trigger osc.). I had it hooked up in place of the Schmitt trigger and it works the way I expected, however I don't know why I only read 2V from my multi meter.
    The Schmitt trigger's pulse read close to 5V.
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Microcontroller with 2 way paging application problem
  4. Serious Serial Situation Setbacks...
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
