What's the voltage on output pin when it's HIGH?
Results 1 to 17 of 17
    when you set a pin to HIGH it should close to Vdd, if not, you probably forgot few things
    disable the Comparator
    disable the ADCs
    this pin is a open-collector type.
    This pin is a INPUT only.. can't be an OUTPUT
    etc etc etc
    since we don't know the PIC and I/O you're using...
    Apr 2006
    I am using 18F452, and reading portb.7.
    It lights an LED the way it should, but I only read 1-2V.
    T
    Quote Originally Posted by TonyA View Post
    With or with out the LED attached?
    Feb 2003
    And if WITH the LED attached, did you also include a current limiting resistor in series with the LED ?
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Apr 2006
    Quote Originally Posted by keithdoxey View Post
    I don't remember... I'll test again and re-post.
    Thanks again,
    T
    Apr 2006
    Yes, with the resistor and LED disconnected, I still read 2V out of the portb.7
    'DEFINITIONS'
    DEFINE OSC 20
    DEFINE ADC_BITS 10        ' Set number of bits in result
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 15
    'PORT SETUP'
    TRISA = %11111111       'set up all pins on portA as input pins
    ADCON1 = %10000010      'Set PORTA analog conversion and right justify result
    timeVar   var word
    pauseTime var byte
    adcin 0, timeVar
    pauseTime = timeVar / 12
    high portb.7
    pause pauseTime
    low portb.7
    pause pauseTime
    I'm using the pic like this to provide a TTL pulse, (replacing a Schmitt trigger osc.). I had it hooked up in place of the Schmitt trigger and it works the way I expected, however I don't know why I only read 2V from my multi meter.
    The Schmitt trigger's pulse read close to 5V.
    Apr 2008
    I see no code saying "port b shall be used for output" .... do you ?
    Ramon.
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Microcontroller with 2 way paging application problem
  4. Serious Serial Situation Setbacks...
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
