What's the voltage on output pin when it's HIGH?
Results 1 to 17 of 17
    Apr 2006
    Default What's the voltage on output pin when it's HIGH?
    I was wondering what voltage is produced on an output pin when it is toggled "HIGH"?
    I always assumed it was 5V, but when measuring it was only 1V, I wondered if my meter is off.
    I am looking for a way to produce a TTL level output pulse; 5V (and 0V) (Similar to the output of a Schmitt Trigger Pulse Oscillator or a 555 timer IC)
    Would I need a transistor for this, or can I just use the Pic by itself?
    Thanks for any advice.
    T
    when you set a pin to HIGH it should close to Vdd, if not, you probably forgot few things
    disable the Comparator
    disable the ADCs
    this pin is a open-collector type.
    This pin is a INPUT only.. can't be an OUTPUT
    etc etc etc
    since we don't know the PIC and I/O you're using...
    Apr 2006
    I am using 18F452, and reading portb.7.
    It lights an LED the way it should, but I only read 1-2V.
    T
    Quote Originally Posted by TonyA View Post
    With or with out the LED attached?
    Feb 2003
    And if WITH the LED attached, did you also include a current limiting resistor in series with the LED ?
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Apr 2006
    Quote Originally Posted by keithdoxey View Post
    I don't remember... I'll test again and re-post.
    Thanks again,
    T
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Microcontroller with 2 way paging application problem
  4. Serious Serial Situation Setbacks...
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
