Quote Originally Posted by xnihilo View Post
Sayzer, Eggman,
Thank you both.
regards!
PS:
Skimask: that was the idea, using a pic to control the stuff but I can dedicate only one pin to control the motor so probably the idea of Sayzer is the one that might best fit my needs... Even if I will need to use relays anyway because the motor will be more than 5V.
Dont forget that the relay will probably take around 25mS to operate and release so a solid state solution might be much better.
thee is also the life of the relay to consider. If you are changing direction every 150ms that is over 3.3 complete cycles of the relay every second. Even with a life of 1 million operations it will take less than 85 hours to reach that figure !!!!!
