Interrupts Identification (handling)
Results 1 to 6 of 6
Threaded View
  1. #5
    Quote Originally Posted by RodSTAR View Post
    LOL so simple ! thank you.
    -something like:
    [code]
    Yess ... so simple
    but.. if I have 10 interrupts enabled and the last interrupt checking ('If' statement) was the triggered, will I always have to check the previous 9 each??, sounds like it will.
    You see anther way to check which has triggered ???
    it's a Pic specifics !!!
    PD: ENABLE & DISABLE are optional, am I ok
    heuuuuu, disable before the interrupt stubb !!! or it will be fun ...
    Ioannis ( hello ...) is right ... BUT if your device shows ~> 2K prog space min. ( say ~> 100 SRAM Bytes ...). The 12F683 is the minimum size to allow something "usable" ...
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. Handling External/Timer Interrupts
    By Tacky3000 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 11:09
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
