Pulse count matching
Results 1 to 6 of 6
    May 2007
    Default Pulse count matching
    Hi all;
    -In a 16F628A, I receive a pulse into a timer, in counter mode, let's say timer1.
    Question:
    -Is there any kind of interrupt flag or trick that tells me when it matches a specified count? (example: when TMR1=231)
    I know QEI does it great in 18F4431 family members, but I don't have them, and I have 12 units of 16F628A here in my desktop.
    Thanks for any ideas or comments
    "Beethoven had his critics too, see if you can name 3 of them"
    May 2007
    Another detail is that at the same time I want to get pulse rate (to calc speed).
    ¿ Should I use:
    -Timer0 (or timer1) as Timer and
    -Timer1 (or timer0) as Counter...
    ... to feed my variables to calculate speed?
    May 2007
    I think in a possible solution:
    Connect my pulse wire to RB6/T1CKI, that is Timer1 input pin, PORTB. Hope I can use RB Port Change Interrupt at the same time as Timer1 is ON. If it is possible, then:
    To get pulse count:
    -when INTCON.0=1 (alias RBIF) interrupt onchange in PORTB, increment MyCounter variable 'manually',
    To get time interval:
    -use Timer1 and calculate speed on each Timer overflow interrupt PIR1.0=1 (alias TMR1IF) or whenever i want
    Is it possible that solution??
    PD:
    [It has come to my mind another question about Interrupts Identification in a new Thread...'Interrupts Identification']
    Too many questions at the same time for me.... I'll start with the first one:
    Question:
    There's at least two ways of doing this as I see it. Either you preset the TMR register with 65535-231 (for a 16bit timer) and when the timer/counter overflows you'll get your interrupt. OR you can use the CCP-module in compare mode, it's designed for doing exactly that. When TMR1 matches the CCPR1 register you'll get an interrupt.
    Wink
    Just open the '628 datasheet ... CCP1 chapter
    11.2 Compare Mode
    In Compare mode, the 16-bit CCPR1 register value is
    constantly compared against the TMR1 register pair
    value. When a match occurs, the RB3/CCP1 pin is:
    • Driven High
    • Driven Low
    • Remains Unchanged
    The action on the pin is based on the value of control
    bits CCP1M3:CCP1M0 (CCP1CON<3:0>). At the
    same time, interrupt flag bit CCP1IF is set.
    FIGURE 11-1: COMPARE MODE
    OPERATION BLOCK
    DIAGRAM
    11.2.1 CCP PIN CONFIGURATION
    The user must configure the RB3/CCP1 pin as
    Isn't life superb ???
    May 2007
    Wink
    Hi Henrik & Alain;
    I'm amazed with both excelent solutions you gave me . I'll use them in other projects I have in mind.
    Nevertheless, Alain's solution can't fit in this particular project, because it is a motor controller. (sorry, but I didn't tell it before to focus the thread on the specific part of the problem)
    Why can't fit in my project?
    Alain's CCP1 solution can't be possible, because as motor controller, I use the unique CCP module in PWM mode to drive motor's H-bridge. (remember it's a PIC16F68A)
    Well, of course Alain (Acetronics) couldn't guess that CCP was unavailable: I had not told it.
    To Henrik's solution, I'll add TMR0 in timer mode, as time reference, for speed calculation. A little bit uncomfortable (8-bit variable), but factible (I hope).
    Thank you Alain and Henrick.
    PD: I would be still more gratefull if any of you give me an opinion on my Post#3.
    Regards!
    Rodrigo
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  3. Indexer not indexing...a basic PBP problem??
    By jellis00 in forum General
    Last Post: - 24th March 2009, 17:53
  4. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  5. Replies: 3
    Last Post: - 13th September 2008, 18:40
