Pic Basic help
Results 1 to 4 of 4
Thread: Pic Basic help
    Apr 2008
    Gainesville, VA
    Default Pic Basic help
    OK, this is probably really simple but I can't seem to make it work. I'm using a IF THEN statement like this: IF (variable) = (a number) THEN (Label)
    Label: some code
    END IF
    When I try to compile, the error message I get is END IF without a matching IF---THEN
    Basically, what I am trying to do is jump out of a loop to "Label" if the variable is a specific number.
    Reading the PICBASIC compiler manual, I can't see what I'm doing wrong. Thanks for any help.
    Klaus
    Start:
            IF MyVar=9 THEN
                LCDOUT $FE,1,"How's Santa today?"
                    GOSUB PassGoAndClaim200Bucks
            IF MyVar=8 THEN
                PAUSE 500
                LCDOUT $FE,1,"Doh!"
                STOP
            IF MyVar=7 THEN WhoLetTheDogsOut
            GOTO Start
    PassGoAndClaim200Bucks:
            '   Plah Plah Plah
    WhoLetTheDogsOut:
            '   Woo... Woo... Woo
            GOTO Start
    Make sure you didn't forgot a ENDIF somewhere in your code while editing it... yeah it happen
    Last edited by mister_e; - 20th April 2008 at 19:45. Reason: typo... sure there's still :D
    Hi Klaus,
    When you have a one-line IF statement you don't use EndIf. So simply:
    If A = B Then myLabel
    should do it.
    Apr 2008
    Gainesville, VA
    Thanks very much. Leaving out the ENDIF worked.
  1. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:09
  2. Loop with two motor and 2 sensors
    Last Post: - 9th December 2008, 00:40
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 02:56
  5. The Ultimate PIC Basic
    By picnaut in forum PBP Wish List
    Last Post: - 9th November 2004, 23:10
