6V to 5V
Results 1 to 11 of 11
Thread: 6V to 5V
    Apr 2008
    Unhappy 6V to 5V
    hi,
    i need a way to take 6V and drop it down to 5V in a 'clean' way, the output voltage of 5V
    must stay pretty constant. I have a motor running off the 6V and a receiver (from a radio control) that needs a constant 5V
    any help would be great, thx
    Do a search for LDO Voltage regulator. Plenty of them here and there.
    Oct 2003
    holland
    Or put 1 or 2 diodes in series with the 6 volt, it drops immediatly!
    Yes, but when the battery will drop of 0.1 volt, the diode output will also be 0.1V less.
    Oct 2003
    holland
    Wink
    It's true what you say !
    Default noise issue too
    Quote Originally Posted by Fisher View Post
    hi,
    Put a small choke in series with whatever power dropping device you have chosen to dampen some of the noise generated by the motor. . .a ferrite bead is useful too, best way is use different power source . . .
    And a capacitor across the motor terminals.
    skimask's Avatar
    skimask Guest
    hi,
    I would think that any receiver could tolerate running from the same supply as your 'motor', with the above mentioned 'cleaning' of the power supply itself from the noise caused by the motor.
    What I think would worry me would be the voltage droop caused by the motor starting up causing the overall voltage to drop too low to support safe operation of the receiver.
    Apr 2008
    Post
    cuz the problem is that i have 2 cordless 18V drills running off of a 6V 42 amp per hour battery with a 12V 38 amp per hour battery. i also have 2 little 12V motors (draws less then an amp) hooked out to the 12V. The reciever needs a constant 5V , i could use a 7805 regulator with the 12V, but i would like to use the 6V for the reciever's 5V.
    These are nice if you do not mind the extra parts.
    http://webench.national.com/ss1/ss?V...1I=.5&op_TA=30
    Aug 2005
    Houston, TX
    If you don't need much current, add a 1K resistor in series and a parallel zener diode.
  1. Generating 5v from 4 batteries
    By BobP in forum Off Topic
    Last Post: - 27th December 2009, 09:46
  2. How to drop from 6V to 5V a "clean" way?
    By flotulopex in forum Off Topic
    Last Post: - 10th October 2007, 10:03
  3. 5v and 7v on same board - question
    By mark.oswald in forum Schematics
    Last Post: - 28th July 2007, 23:03
  4. One wire serial comms on +5V line
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 21st May 2005, 12:49
  5. Replies: 5
    Last Post: - 23rd February 2005, 17:35
