Exsrtacting data
Results 1 to 7 of 7
    Default Exsrtacting data
    Can anyone please help
    I am trying to exstract data from a string of serial data from a sms modem
    THE string
    ^SMGL: 1,"REC UNREAD","+27829554322",,"08/04/20,17:12:09+08"
    test
    I need to exstract the cell number from this after reading some posts recomending debugin
    i tried hserin the idea is to use a interupt and as soon as data comes in decode it, test the sell number and if it is a recognized number ecsecute the command in the message field
    This is the command i thought would work but my program hangs
    HSERIN [WAIT("SMGL:"), SKIP 18 , V5]
    Any help would be appreciated
    so ^SMGL: 1,"REC UNREAD","+27829554322",,"08/04/20,17:12:09+08" is EXACTLY what you see in hyperterminal or else terminal?
    27829554322 should be the number to extract number by number and then compare with a specific one or a table of?
    Did you tried with STR and a BYTE array?
    Did you tried your hardware with a PC to PIC communication (with MAX232)?
    Hi there,
    I am using a serial port on my pc sending the data via an rs232 chip to a 16f913
    Below is my code that shoed reply with the message number and the cell number but nothing happens any suggestions
    [CODE]
    INCLUDE "MODEDEFS.BAS"
    DEFINE OSC 20 ' Define crystal as 20Mhz
    '*Serial port Setup 9600 8N1*
    DEFINE HSER_BAUD 9600 ; 9600 Baud
    DEFINE HSER_CLROERR 1 ; Clear overflow automatically
    '*ADC setup*
    DEFINE ADC_BITS 10 'SETS NUMBER OF BITS IN RESULTS 8,10,12
    DEFINE ADC_CLOCK 3 'SETS CLOCK SOURCE (RC = 3)
    DEFINE ADC_SAMPLEUS 50 'SETS SAMPLING TIME IN MICROSECONDS
    'This Part set PORTA 0-5 an analog inputs
    ADCON1 = %01110000 'FRC (clock derived from a dedicated internal oscillator = 500 kHz max)
    ANSEL = %00011111 'The ANSEL (91h) and CMCON0 (9Ch)registers must be initialized to configure an
    CMCON0 = %00000111 'analog channel as a digital input. Pins configured as analog inputs will read ‘0’.
    TRISA = %00011111 'set PORTA 0-5 as inputs
    ADCON0.7 = 1 'Right justify output of ADC datasheet P145 of 16F913
    TRISC = %10000000 'Set PORTC for serial coms and pins as output
    TRISB = %00000000 'Sert PORTb as outputs and for use with the ICD2
    INTCON = 0 ;Disable interrupts
    V1 var WORD
    ID var byte[28]
    PORTC = 0
    loop:
    'ADCIN 0,V1
    HSERIN [WAIT("^SMGL:"),SKIP 1 ,str ID\28]
    HSEROUT ["MES NO:",dec ID[0],10,13]
    HSEROUT ["CELL NO:",dec ID[17],dec ID[18],dec ID[19],dec ID[20],dec ID[21],dec ID[22],dec ID[23],dec ID[24],dec ID[25],dec ID[26],10,13]
    goto loop
    [END CODE]
    Do you have a level translator between PIC-Phone? Like a MAX232?
    A this stage i use my PC to send the data to the pic via a SP232ACP chip
    it works here using...
    loop:
            'ADCIN 0,V1
            HSEROUT ["MES NO:",ID[0],10,13]
            HSEROUT ["CELL NO:",_
                    ID[17],iD[18],ID[19],ID[20],ID[21],ID[22],_
                    ID[23],ID[24],ID[25],ID[26],ID[27],10,13]
            goto loop
    <img SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2533&stc=1&d=120888300 3">
    Check your Config fuses setting, make sure you have HS_OSC enabled.
    Thanks got it working ,needs to remember to copy all include files next time i format my pc
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
