Quote Originally Posted by yasser hassani View Post
I simulated your program with proteus. It worked correct.
I want to use PIC16F877.
Hi, Yasser
It's up to you to choose which pic you want to use ( they call it "democracy" . LOL ) ... just note LCD + ext EEPROM + 1 Pushbutton can be driven by a 18 Pins Pic... not to say a 16C84 ...
[Humour]
Simulation, simulation, ... that do not exist in the real World ... Last time I tried to simulate a 555 on that thing ( démo example GIVEN !!! ) ... just returned me "ERROR" !!!
This soft is sold ... 15000 US $ !!!
The 555 on its bredboard was working fine ...
[/Humour]
I know that micro's eeprom hasn't 1500b memory.
You know, I want to use serial eeprom for example 24c04 (4K bit)
Also note 1500 BYTES need a 24LC16 to fit into ( 1500 *8 = 12000 ...)
Can you help me about changes on your written program for using serial eeprom ?
I think that I should use i2cread command like below:
i2cread sda , scl , ctw , I , Value
Something like that ... yes !
I'm not so used to external EEPROMs ... so, I'll need some little hours to "update" my knowledge ... but I've seen that subjects have been fully covered on this Forum ...
I will encourage you to carefully read the 5.34 and 5.35 $ of the new and "Web" manuals, ( 5.29 and 5.30 Oooooold one ) as there is interreaction between the control Word and addresses for those EEPROMS ...
I keep on the line ...
read you soon
