' Processor 16F877a @ 4Mhz
'Yasser's light or text show
' IMPORTANT NOTE
' The 16F877a shows only 256 EEPROM Bytes ...
' DO NOT ASK IT 1500 !!!
'* LCD Defines for EasyPic5 *
' DEFINE LCD_DREG PORTB ' I/O port where LCD is connected
' DEFINE LCD_DBIT 0
' DEFINE LCD_RSREG PORTB
' DEFINE LCD_RSBIT 4 ' Register select pin
' DEFINE LCD_EREG PORTB
' DEFINE LCD_EBIT 5 ' Enable pin
' DEFINE LCD_BITS 4 ' 4-bit data bus
' DEFINE LCD_LINES 2 ' LCD has 2 character lines
' DEFINE OSC 8
'* LCD Defines *
DEFINE LCD_DREG PORTD ' I/O port where LCD is connected
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTD
DEFINE LCD_RSBIT 2 ' Register select pin
DEFINE LCD_EREG PORTD
DEFINE LCD_EBIT 3 ' Enable pin
'Chip initialization
ADCON0 = 0
ADCON1 = 7
CMCON = 7
CVRCON = 0
'Variables & aliases
' Scroll var PORTA.0 ' Start and Scroll up/dn button
Scroll var PORTB.4 ' Start and Scroll up/dn button
Index var Word
I var Word
Delay var Byte
Value var Byte
Cold var Bit
'Variables initialization
CLEAR
Cold = 1
'Constants
Endaddress CON $FF' 05DC 'Memory last address to read
ScrollPause CON 400 'ReadPause duration in ms
'PORTS Initialization
PORTA = 0
PORTB = 0
PORTC = 0
PORTD = 0
PORTE = 0
TRISA = 0
TRISB = %00010000
TRISC = 0
TRISD = 0
'LCD Initialization
LCDOUT $FE,1 'Clearscreen
PAUSE 700
Coldstart:
Delay = 0
BUTTON Scroll,1,255,0,delay,1,Released
IF cold THEN
LCDOUT $FE,$80," Hello Yasser " ' Waiting Message
LCDOUT $FE,$C0,"Waiting for you"
cold = 0
goto ColdStart
Released:
Delay = 0
BUTTON Scroll,1,255,0,delay,1, Released ' Wait for button release
LCDOUT $FE,1 'Clear Screen
Increase:
Index = I
FOR I = Index to (Endaddress - 1) Step 2
READ I,Value
LCDOUT $FE,$80, BIN8 Value," ",DEC3 I 'BIN8 for Binary, may be decimal or character
READ I+1,Value
LCDOUT $FE,$C0, BIN8 Value," ",DEC3 I+1
PAUSE ScrollPause
Delay = 0
BUTTON Scroll,1,255,0,delay,1,Decrease 'Reverse Scrolling requested ?
NEXT I
I = 0 'No toggle ... let's rewind Index = 0
Goto Increase
Decrease:
Index = I
FOR I = Index to 1 Step - 2
READ I,Value
READ I+1,Value
PAUSE ScrollPause
Delay = 0
BUTTON Scroll,1,255,0,delay,0,Increase 'Continue Reverse scrolling ?
NEXT I
I = EndAddress -1 'No toggle ...let's rewind Index = Endaddress
Goto Decrease
